nitrous with boost?
Old Aug 11, 2004 | 08:34 PM
forced00si's Avatar
Default nitrous with boost?
I was wandering if I could run a 35 shot or so on a stock block at10 psi vortech. It looses assloads of power in hot humid wheather.... so wacha think? Will it kill it instantly or will the cooling effect make it **** and get?
Old Aug 11, 2004 | 08:59 PM
MooreBoost's Avatar
Default Re: nitrous with boost? (forced00si)
Most people run nitrous on their boosted cars to help with turbo lag. You have lag, but I dont think nitrous will alleviate it because of the type of blower it is. Im not sure to be honest, but in either case, you would want to run a boost pressure switch that turns off the nitrous at a given PSI. Boost and nitrous will send your cylinder pressures sky high, which wont be friendly with stock internals. Do you have the aftercooler?
Old Aug 11, 2004 | 09:03 PM
forced00si's Avatar
Default Re: nitrous with boost? (tegunderpressure)
Yeah, its aftercooled. The lag isn't a big problem because it gives some time to hook. I mostly notice about 3mph slower in the 8th mile and about 3-4 tenths.
Old Aug 12, 2004 | 05:37 AM
MooreBoost's Avatar
In that case I wouldnt do it, unless you use the pressure switch, but that may lead to traction issues. Your call though.
Old Aug 13, 2004 | 04:06 PM
forced00si's Avatar
How many psi should I cut it off ?? I have a rpm window switch that would let me turn it on at say 5500 and cut it off at say 7500 just to make the power curve of the vortech look more "NORMAL"..
Old Aug 13, 2004 | 05:38 PM
civictypenos's Avatar
no nitrous,do propane injection,get a hobbs switch to turn the propane on at 3-4 psi,it will do wonders and its like having race gas on demand,cost ya $3 a month or even less.
Old Aug 13, 2004 | 10:11 PM
forced00si's Avatar
Default Re: nitrous with boost? (civictypenos)
Tell me more... Where to get or how to make kit ect.?
Old Aug 14, 2004 | 09:18 AM
http://www.h20injection.com/
Old Aug 15, 2004 | 06:39 PM
forced00si's Avatar
Thank you so much. Going there now to check it out!
4thgenx42
Apr 28, 2007 08:40 AM
fast93accord
Aug 18, 2005 02:47 PM
99AccordTurbo
Sep 12, 2004 10:43 PM
typesguy
Feb 26, 2004 01:58 PM
hybrid901
Jul 15, 2002 02:29 PM
