Newbie, couple of questions
Old Aug 11, 2004 | 07:34 AM
BrownGSR's Avatar
Default Newbie, couple of questions
I have a 94 gsr, good comp across the board. I have 111,xxx miles. I am going to the darkside after some all-motor hi-jinx. I dont know too much about them so I thought I wold ask
Looking to get a quality kit and spending aprox. 3,000$ or so.
Pros and cons on the Rev Hard stg 2 and the Drag 3 Kit
Also what about putting a kit together, cheapturbo has some nice stuff.
Thanks for the help and insight
Old Aug 11, 2004 | 11:18 AM
BrownGSR's Avatar
Default Re: Newbie, couple of questions (BrownGSR)
well can i get any love at all???
Another quick question, since i have an integra, do i have to switch to a small (single fan) rad?>
Old Aug 11, 2004 | 11:24 AM
mike1114's Avatar
not trying to be a dick but many are gonna tell you to search. The Greddy vs drag vs whatever has been discussed many times.
My $.02 is to build your own kit. Spend the next few months reading on Honda-Tech and researching. I have some good websites for you to start with if you want. Then, piece together what YOU want, what you have read works well for others. You buy a kit and eventually as you gain more knowledge, you start replacing part after part, with what you REALLY WANTED.
Spend good money on the fuel/engine management, cheap out somewhere else, cause if you go cheap with the engine management, you'll run like **** and eventually **** something up.
Old Aug 11, 2004 | 12:29 PM
brickonwheels's Avatar
or instead of you piecing together a kit, you could also buy a used one. Thats what i did and i got a great deal on stuff that had been used for only a few weeks.
Old Aug 11, 2004 | 12:59 PM
-Trinitron-'s Avatar
research and piece your own kit. you will have a better setup for less money in the end.
Old Aug 11, 2004 | 02:08 PM
turbosi03's Avatar
Default Re: (-TRINiTRON-)
I started out with a drag 3 kit... now the only things on my setup from that kit are some intercooler pipes, BOV, and the snail... the snail will be upgraded soon.
research & build own kit is the way to go...
Old Aug 11, 2004 | 04:18 PM
T-RO's Avatar
I spent 1.5 yrs gathering all my turbo parts (mainly cause i'm a broke *****).
I spent $700 Total on my setup... Not the fastest but its fun and I want to Auto-X rather than Drag race. Its also my Daily Driver She pulls but needs to be fine tuned...
1994 Civic EX Coupe
Stock D16z6 w/109,xxx mi
JDM D15b Head w/50,xxxmi
DSM T25 turbo (running 8psi but spiking to 11)
1g DSM BOV
HF manifold
Home made adapter plate
ARP Headstuds
RX7 460cc injectors
'99 Civic Si fuel pump
Johnny racecar 5" FMIC
2" charge piping
2.5" Downpipe
Stock cat
2.25" Mandrel bent cat back exhaust
Trust "Cherry Bomb" resinator
Unknown muffler
Run by Crome
Old Aug 11, 2004 | 09:43 PM
donkiman's Avatar
well the best "kit" out there is the full-race kit from http://www.full-race.com but you can easily piece your own together. find out what your hp goals are and then just read the posts for what other people with that power are running. also as the other guy said dont skimp on engine/ fuel management. I personally run a t3/to4e on my gsr motor in my civic. I see full boost at around 4000rpm. im only boosting 11 pounds but the turbo maxes out at 400hp so it leaves room to expand. also to cut costs you can find some really good deals on used stuff. good luck.
Old Aug 13, 2004 | 10:57 AM
BrownGSR's Avatar
Default Re: Newbie, couple of questions (donkiman)
so what are some good quality pieces, I have been looking at manifolds (full-race and love-fab) do i really need equal length or just a log will be fine. I will def go with a tial wastegate, but what is a good bov and fmic. Thanks for all the help.
What about a downpipe and its size? I am going to order my 3in exhaust from kteller. Also what is the diff in 4bolt or 5bolt flanges?
Sorry i dont know much, but i have been trying to learn all i can
Old Aug 13, 2004 | 10:58 AM
BrownGSR's Avatar
Do i need a half-sized rad so the turbo/wastegate/mani will fit???
Old Aug 13, 2004 | 11:00 AM
Ya@inlinePRO's Avatar
you don't even have to search.
just look through the threads below. there are nice #'s just look at what they have done.
greddy has always been a quality kit! great starter kit
Old Aug 13, 2004 | 11:20 AM
BrownGSR's Avatar
what about internal and external wastegates
and fuel management. Hondata, e-manage, Vafc hack(which i have already)
Old Aug 14, 2004 | 11:31 AM
BrownGSR's Avatar
bump
milton
Dec 14, 2004 11:02 PM
Rocks
Sep 10, 2004 10:23 AM
libila
Feb 21, 2003 09:22 AM
fastacurachick
Feb 13, 2003 12:36 PM
JDubya
Jul 28, 2002 10:35 AM
