what size intercooler piping
Old Aug 11, 2004 | 01:42 PM
dornon13's Avatar
Default what size intercooler piping
i am looking for a good size intercooler piping at work we have a 3in. aluminum tube with an inner diameter of 2.5in. could i use this or would it hurt my performance...
Old Aug 11, 2004 | 01:51 PM
turbo*s2k's Avatar
Default Re: what size intercooler piping (dornon13)
I use 2.5" piping on my setup. I believe the standard drag kits come with 2.25". I recommend 2.5". What are your hp goals?
Old Aug 11, 2004 | 01:52 PM
Frozen E's Avatar
H-T White Ops
Most intercoolers have 2.5 OD openings. I ordered 2.5" OD piping to do my home made piping. I don't know about the 3" thing. It would work, but I've seen posts here that say a 3" charge pipe would slow down your spool time a little bit after shifting by a few hundredths of a second. I don't see a big problem with using 3" myself. Maybe somebody else will throw in their $.02 for ya.
Old Aug 11, 2004 | 04:49 PM
dornon13's Avatar
Default Re: (IslandSi)
yeah i think u are prolly correct with the lag.. i will most likely just have some piping made for me or buy one from somewhere is there a place that sells mandrel bent intercooler piping?
Old Aug 11, 2004 | 05:48 PM
Frozen E's Avatar
H-T White Ops
Check out this site. Has part numbers for mandrel bent pipe and where to get the pieces from.
http://www.cse.uconn.edu/~yele....html
Also has some round about instructions on where to cut the pieces.
Old Aug 11, 2004 | 06:13 PM
Bailhatch's Avatar
The 1/4" walls on your alu pipe are super excessive. I'de just buy 3 16g steel mandrel Js for like 60 bucks and be done with it.
Old Aug 11, 2004 | 06:43 PM
dornon13's Avatar
Default Re: (Bailhatch)
well here is the reason i mentioned that size pipe...i work at a factory that makes parts that use that size piping...i can make my piping out of that for free..and so my question was just if it would be beneficial. if i had a choice anyways i would venture to say that aluminum would be the smartest metal to use...lighter and disperses heat better
Old Aug 11, 2004 | 07:24 PM
dunkd's Avatar
what are your HP goals?
Old Aug 11, 2004 | 08:09 PM
dornon13's Avatar
Default Re: (dunkd)
i am trying focus on the 300hp range and try to get that as low in the powerband as i can i dont want to have to rev to 9k to get 300hp ya know what i mean..i guess my main goal is to eventually hit 11s when the susp.is setup pretty nice...the engine will be a 2.0L lsvtec with stock GSR head and forged internals rebuilt like its brand ****** new. but yeah basically i wanna get some very low spool times and prolly max out at 300hp. help is very needed i know about turbos and stuff but i dont know what makes a GOOD turbo setup other than quality products if that makes any sense.
Old Aug 11, 2004 | 08:20 PM
dunkd's Avatar
2.5" will be perfect for you...
Old Aug 11, 2004 | 08:22 PM
dornon13's Avatar
Default Re: (dunkd)
any other suggestions for my hopes of low spool? how small of a turbo would you recommend?
Old Aug 11, 2004 | 08:31 PM
dunkd's Avatar
if ur looking for low spool use as less intercooler piping as possible and a intercooler that isnt very long... also a 2.25" turbo to intercooler pipe would help
Old Aug 11, 2004 | 09:37 PM
dornon13's Avatar
Default Re: (dunkd)
so are u saying 2.25 turbo to intercooler and 2.5 from intercooler to intake? that sucks about the intercooler they look so cool lol
Rodzknight
Feb 14, 2008 08:42 AM
QuarterMileMaster
Jan 26, 2005 05:24 AM
VtecAdil
Oct 7, 2004 03:36 PM
ghettochild
Aug 10, 2004 07:02 PM
