Wideband question
Old Aug 12, 2004 | 11:16 AM
dornon13's Avatar
Default Wideband question
I understand what wideband is i am just wondering if when you install the wideband does its reading go to the ecu or does it just go to the display to give you a reading....i am wondering if it runs to the ECU and gives it a more accurate reading which in turn runs your engine "better" thanks
Old Aug 12, 2004 | 11:30 AM
underpressure02's Avatar
Default Re: Wideband question (dornon13)
It goes to the display unless you wire it into your EMS. There was just a thread on this a few mins ago in the FI forum. Search there is tons of info on this.
Old Aug 12, 2004 | 11:34 AM
The-LS's Avatar
it goes to a seperate display, you can wire some back into the ECU but you need to program the WB unit to output to something the ECU can read. The Innovate LM1 is one such WB that can do this.
Old Aug 12, 2004 | 11:40 AM
Muckman's Avatar
Moderator in Chief
stock ecu's cannot understand a 5v input from a wideband. they are setup to use a 1v narrow band input. it would blow its mind.
Old Aug 12, 2004 | 12:08 PM
dornon13's Avatar
Default Re: Wideband question (Muckman)
i did read that post and it didnt answer my question unless something had been added after i read it. but thankyou guys for answering my question.
Old Aug 12, 2004 | 12:15 PM
Big Bang's Avatar
The Zeitronix unit also has a narrowband output for a ECU. I've got mine hooked up like that and it seems to work really well for me
Old Aug 12, 2004 | 11:02 PM
turtle-eg's Avatar
On Hondata, you can feed the 5v signal into the o2 wire and datalog with it or you can send the signal to the display or both.
Old Aug 13, 2004 | 12:55 AM
shermanyang's Avatar
Default Re: Wideband question (turtle-eg)
on my AEM EMS i'm able to either just send it to display on my laptop...or use WideBand O2 feedback which allows me to adjust/correct my a/f at any given rpm/engine load. i was messing around with this option today during work and it seems to work pretty decently looking at my datalog files
slammedz6ef
Feb 6, 2008 10:28 PM
Berlinetta F1
Sep 1, 2007 06:06 AM
Siegfried
Mar 29, 2004 09:36 PM
