turbo rsx problems
Old Aug 12, 2004 | 11:45 AM
HairDriedRsx's Avatar
Default turbo rsx problems
i started my car this morning. it was about 55 degrees so i had to wait a while for it to warm up. once i started driving it i noticed it was very rough and had little power. i thought it was a fuel problem but im not sure yet. it was running great last night but this morning it was messed up. any help would be great
Old Aug 12, 2004 | 11:48 AM
Muckman's Avatar
Moderator in Chief
Default Re: turbo rsx problems (HairDriedRsx)
How about including more than zero information on your setup.
How is it tuned?
Old Aug 12, 2004 | 12:18 PM
h22blazerz5's Avatar
Default Re: turbo rsx problems (Muckman)
yeah tunin is a must
Old Aug 12, 2004 | 12:19 PM
its tuned with hondata 440 injectors t3-t4 turbo no internals 7-8 psi
Old Aug 12, 2004 | 12:26 PM
JDMCRX's Avatar
Did u check the basic's like plugs,air way is clear,fuel is ok.
Maybe it was just to hot out and the car is too rich.
Take it for a drive and when it does that prob pull over take ur plugs out and read them. TOo rich or too lean
Old Aug 12, 2004 | 12:29 PM
Default Re: turbo rsx problems (JDMCRX)
the weird thing is it happend over night could the cold weather change anything? like the function of the injectors or plugs?
Old Aug 12, 2004 | 01:23 PM
toolowsol's Avatar
cold weather can change it yes... You'll run lean.
Old Aug 12, 2004 | 01:29 PM
Default Re: turbo rsx problems (toolowsol)
i found out the problem i bent a valve or two on one of the cylinders
compression checks out on all of them and the injectors are fine and so are the plugs which show that im running really rich.
Old Aug 12, 2004 | 01:33 PM
B18 CYA's Avatar
bent a valve or 2 on one of the cylinders? u mean bent a rod in one of the cylinders....
Old Aug 12, 2004 | 01:42 PM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HairDriedRsx &raquo;</TD></TR><TR><TD CLASS="quote">i found out the problem i bent a valve or two on one of the cylinders
compression checks out on all of them and the injectors are fine and so are the plugs which show that im running really rich.</TD></TR></TABLE>
How did you bend the valve? It just dosent happen?? How is a valve in a cylinder?
Also how is the compression ok if you have a bent valve??
Something smells fishy
1sickemtwo
May 16, 2017 08:22 PM
demerybuiltls10
13
Oct 26, 2011 10:50 AM
boosted2001lx
Honda Civic (2001 - 2005)
Aug 22, 2008 05:52 AM
EF_338
13
Sep 20, 2006 01:07 PM
Used2beAb16
Apr 13, 2005 06:54 AM
