Tach Jumping
Old Aug 15, 2004 | 05:51 PM
jrponline's Avatar
Default Tach Jumping
Last week my car's tach started doing something weird. After I get into full boost (9psi) it starts to jump around as if it had a loose connection. It doesn't though, as this only occurs in high boost, not at any other times.
Car is a del Sol B16A w/turbo, factory ignition system.
Thoughts / Suggestions?
Old Aug 15, 2004 | 05:56 PM
beepy's Avatar
Default Re: Tach Jumping (jrponline)
It's misfiring. Be careful.
Old Aug 15, 2004 | 06:59 PM
R THIS's Avatar
Default Re: Tach Jumping (beepy)
thats a misfire.... if you listen carefuly you probably hear the exhaust note change....
check your spark plug gap...
are you running an msd???
Old Aug 15, 2004 | 07:46 PM
jrponline's Avatar
Default Re: Tach Jumping (R THIS)
You guys are right, this started happening right after I changed spark plugs. I went back to my NGK's which I know were properly gapped and the problem is gone. Thanks!
(no msd, factory ignition system)
Old Aug 15, 2004 | 07:53 PM
R THIS's Avatar
hey i just realized ur from mississuga,,, is ur delsol green????
Old Aug 15, 2004 | 08:05 PM
Ryan C's Avatar
what plugs and what gap were you originally running?
Old Aug 15, 2004 | 08:16 PM
jrponline's Avatar
no, its a black 96.. I work at JRP if you wanna see it.
Ryan C: I am running NGK BKR7E's stock number 6097. I don't recall the gap I'm using, but its slightly smaller than how they come out of the packaging.
Old Aug 15, 2004 | 08:38 PM
R THIS's Avatar
thats cool i think i seen it before
Project X
Sep 15, 2007 02:56 PM
hondaeg8
Dec 8, 2004 08:18 PM
servion
Sep 20, 2004 05:50 PM
B_1_8_hatch
Dec 2, 2003 03:13 AM
