has anyone use the cheapturbo oil line kits
Location: chillin in that city called queen creek, but homes the atl
https://honda-tech.com/zero...age=1
has anyone use the cheapturbo oil line kits and if so is the nut for the oil pan brass and if it is brass did anyone have a hard time welding it on just looking for comments on the kit
Re: has anyone use the cheapturbo oil line kits (streetdreams02)
I havent personally used it but every turbo'ed honda Ive seen uses material cheaper and less quallity then that. I planed on using those lines myself; I think you would be fine if you wanted to run them.
gl! Let me know how it goes if you do
Re: has anyone use the cheapturbo oil line kits (jdmjerk)
I have them, i didn't weld the fitting on, i just screwed it in and put the nut and washer on the back, it leaks slowly, so i'm going to put some jb weld around the outside to seal it better
Re: has anyone use the cheapturbo oil line kits (toolowsol)
hey that is a decent idea i never thought about that but is that the only problem that u have had
The brass fitting w/ a nut on the back is not to be welded. We have another fitting for weld-on that can be purchased by request. The leaking fitting it is not submerged in oil is it?
Re: has anyone use the cheapturbo oil line kits (cheapturbolines.com)
thanks for jumping in how much is the weld on fitting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheapturbolines.com »</TD></TR><TR><TD CLASS="quote">The brass fitting w/ a nut on the back is not to be welded. We have another fitting for weld-on that can be purchased by request. The leaking fitting it is not submerged in oil is it? </TD></TR></TABLE>
Not submerged, but i'm guessing when the oil starts splashing around it could be... I'm going to jbweld it up tonight.
PS: The leak is VERY MINIMAL, about a quarter size spot after I park, I'm thinking it leaks a little when i drive, and then when i park the excess drips off the pan. JB weld should seal it up tight though
i'm using the cheapturbolines kit.. hopefully it doesnt leak.. i have a washer to space it out a bit so its really snug.. otherwise jb weld it a bit...
hey thanks everyone i guess i will buy the kit now
good luck with the search there havin a sale @ the yard on the 4th and 5th maybe youll get lucky and find one there i found alot of **** there thisweekend
