greddy boost controller
Old Aug 14, 2004 | 05:09 PM
vangc6780's Avatar
Default greddy boost controller
can a the greddy b/c 2 can that make the turbo spool a little quicker???
if so what is the settings for it....
Old Aug 14, 2004 | 11:18 PM
Chris F's Avatar
Default Re: greddy boost controller (vangc6780)
profec B spec 2?
You can change the start boost (aka set gain) closer to your desired boost pressure, (desired pressure - 4 psi). That's the pressure where it starts opening the wastegate.
https://honda-tech.com/zerothread?id=931190
You can't make it spool at a lower RPM, but you can hold your wastegate closed a little longer.
90210tegrunner
Dec 22, 2011 04:22 PM
jspecegseis
Jun 22, 2007 08:53 AM
maddog20
Aug 4, 2003 03:07 AM
