WTF is up with my timing?...
Old Aug 13, 2004 | 10:28 AM
*Boostwerks*'s Avatar
Default WTF is up with my timing?...
I checked my timing again today with my light because I had plans on advancing the base timing by a few degrees (compensate for larger bore, and low compression).
When I started the car, let it warm up (the RPM was about 800) and checked the timing, the #1 cylinder was firing just behind TDC...
This suprised me mainly because I checked the timing when I first got the motor in, and it was just about 16 degrees advanced.
Sooo...I advanced the distributer ALL the way, and its just about half way towards the 16degree mark.
WTF is going on? My Cam timing, is perfect.
0 codes, and the motor runs strong as hell (obviously not as strong as what it could be).
Any ideas?
TIA,
Bryson
Old Aug 13, 2004 | 12:15 PM
DIRep972's Avatar
Smarter than you
Default Re: WTF is up with my timing?... (Bryson)
Cam gear slipping?
Old Aug 13, 2004 | 12:21 PM
Sonny's Avatar
Are you using the service connector to force the CEL on when checking/setting the timing?
Sonny
Old Aug 13, 2004 | 12:24 PM
B18C1CYA's Avatar
Default Re: WTF is up with my timing?... (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny
</TD></TR></TABLE> i tryed to do my timing with out doing this and it was doing the same thing almost.
Old Aug 13, 2004 | 12:43 PM
Muckman's Avatar
Moderator in Chief
Recheck timing belt?
Old Aug 13, 2004 | 12:51 PM
PM-Performance's Avatar
Sonny
as much as everyone says its needed to do this its not, ive done it both ways and the same results.
check the timing belt though. make sure its not off teeth
Old Aug 14, 2004 | 01:42 PM
Default Re: WTF is up with my timing?... (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Recheck timing belt? </TD></TR></TABLE>
Its perfect.
I'm kinda thinking it might be my freinds timing light. Why? because I rechecked the timing today, and its firing right on.
However, I still have the distributer fully advanced...
I"ll prolly get my own light, just to make sure.
EX-T
Jan 21, 2009 04:16 PM
johnwohl
Apr 1, 2008 07:29 PM
northemt88
Mar 15, 2008 12:57 AM
integ u
Aug 5, 2003 09:39 AM
