good bov for 7psi?
Old Aug 11, 2004 | 05:13 PM
AF-b16a1's Avatar
Default good bov for 7psi?
the bov i have (rfl) doesnt seem good on my car...i was wondering what is a good for a 7-8 psi...plus i want it kinda loud...i love that high pitch pshh noise...haha i am so rice
Old Aug 11, 2004 | 05:17 PM
B00ST2nR's Avatar
Default Re: good bov for 7psi? (AF-b16a1)
I like the Tial's
Old Aug 11, 2004 | 05:22 PM
AF-b16a1's Avatar
Default Re: good bov for 7psi? (B00ST2nR)
how loud do they get?
Old Aug 11, 2004 | 06:11 PM
AF-b16a1's Avatar
anyone else know a good bov with a 7 psi spring?
Old Aug 11, 2004 | 06:33 PM
frostcivic's Avatar
blow off valves have different psi springs? i thought that was only for wastegates...
Old Aug 11, 2004 | 06:52 PM
CalGSR99's Avatar
Default Re: good bov for 7psi? (frostcivic)
Yeah, the tial BOV is spring loaded. I read from http://www.roadraceengineering.com that these are recommended for high HP cars. If you run low boost they sound like a dying dolphing under your hood. That is what they said, I dont have a tial BOV so i cant back that up.
I do have a Greddy Type-S BOV that is adjustable. Its loud and i can adjust it for whatever boost i run (no spring needed). I like it. But tial makes real good products. I saw go with greddy type-S. But i would also like to hear how the tial BOV holds up. Good luck.
Old Aug 11, 2004 | 07:06 PM
AF-b16a1's Avatar
thanks someone told me that the type s is good with sohc...so i might pick one up...thanks for the help people...
Old Aug 11, 2004 | 07:20 PM
SpdFrk's Avatar
What about hks ssqv?
Old Aug 11, 2004 | 07:25 PM
dunkd's Avatar
i have turbo xs rfl on my car ~9psi and its great...
Old Aug 11, 2004 | 07:47 PM
beepy's Avatar
Default Re: (dunkd)
1st-gen DSM. Works every time, even under very low boost.
Old Aug 11, 2004 | 08:02 PM
B16Drag's Avatar
Turbo XS RFL is loud, thats why its called RFL => "REAL PHUCKEN LOUD"
you just need to have it mounted further away from your throttle body and closer to your turbo.
Old Aug 11, 2004 | 09:20 PM
donkiman's Avatar
Default Re: good bov for 7psi? (SpdFrk)
hks ssq
Old Aug 11, 2004 | 09:43 PM
AF-b16a1's Avatar
Default Re: good bov for 7psi? (donkiman)
what does the hks sound like?
Old Aug 11, 2004 | 10:12 PM
Si[R]'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote">hks ssq </TD></TR></TABLE>
off topic but would one have to adjust the hks ssq when running more power/psi??
Old Aug 11, 2004 | 10:44 PM
AF-b16a1's Avatar
Default Re: good bov for 7psi? (Si[R])
what are the spring ratings on those hks bovs?
Old Aug 11, 2004 | 10:47 PM
Tchleung's Avatar
The HQS SSQ is adjsutable via bolt on the end so you can adjust the stiffness of the spring to your desired boost level or "sound" shall I say hehe.
Old Aug 11, 2004 | 10:51 PM
Si[R]'s Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">The HQS SSQ is adjsutable via bolt on the end so you can adjust the stiffness of the spring to your desired boost level or "sound" shall I say hehe.</TD></TR></TABLE>
so by adjusting the pin on the back of the hks ssq you allow it to handle more power/psi??
Old Aug 11, 2004 | 11:30 PM
Tchleung's Avatar
Default Re: (Si[R])
In a sense yes. the more boost.t he higher tension you would want to set it to.
mahatma
Apr 10, 2007 02:37 PM
integra3586
Jan 20, 2007 05:49 AM
94greddycivic
Apr 28, 2004 04:43 AM
b18bturbo
Apr 26, 2004 06:46 AM
Screamer
Mar 27, 2003 08:36 AM
