Compressor trim help
Old Sep 27, 2004 | 11:03 AM
shawn_crx's Avatar
Default Compressor trim help
which one will make the more power
T4 52 trim compessor?
or
T3 60 trim compessor?
power/flow psi/psi
Old Sep 27, 2004 | 11:09 AM
adseguy's Avatar
Default Re: Compressor trim help (shawn_crx)
same turbines?? They will match up pretty well, but i think if you look at the compressor map the t4 52 trim will generate more power.....not sure...i should look at the compressor map before speaking . I do know it'll be close though.
Old Sep 27, 2004 | 11:21 AM
shawn_crx's Avatar
Default Re: Compressor trim help (adseguy)
Yeah with the same turbine.
Old Sep 27, 2004 | 03:59 PM
shawn_crx's Avatar
Here is the spec.
T4 compressor .50 a/r
74mm ex.
55mm ind.
I search and the only wheel that match up with that spec is the GT35 52 trim.
not sure.
The thing is that i have the t4 turbo and t3 turbo.
I was going to mate them into t3/t4.
Then was thinking that the t3 is 60 trim.
and the t4 is 52 trim.
Just want to make if the t4 pushes more then I'll mate them in t3/t4. If not I'll just run straight T3
TurboJesse
Mar 24, 2003 07:27 PM
revhardsi
Dec 23, 2002 10:21 AM
Ri5e
Aug 24, 2001 07:59 AM
