Turbo seals
Old Sep 26, 2004 | 05:08 AM
crispydee's Avatar
Default Turbo seals
Im pretty sure the seals have gone on my NEW turbo. Where can i get a rebuild kit from for a T3?
Old Oct 4, 2004 | 07:35 AM
Raunch's Avatar
Default Re: Turbo seals (crispydee)
bump I need to know too.
Old Oct 4, 2004 | 07:37 AM
mattcalica's Avatar
i acutally think theres a lot of rebuild kits on ebay...u should check there...also, i think cheapturbo.com has some rebuild kits as well, but i could be wrong.
Old Oct 4, 2004 | 10:36 PM
crispydee's Avatar
Default Re: (mattcalica)
Thanks for the info but ive sourced one now from a company just a mile from my house. there kit was £35 which is about $65 soo not the end of the world. But the problem is not sorted yet please see post below
https://honda-tech.com/zerothread?id=1012671
Old Oct 5, 2004 | 01:09 AM
swlabhot's Avatar
Default Re: (crispydee)
Are you sure that your oil return line is done preoperly? I had the same problem and just had it replaced last night and a quick blast up the road seems to suggest that it is now OK. I guess I need to put more miles on it just to be absolutely sure.
If you are sure your new oil return is good (got a pic of it?), and it still smokes slightly then it could just be the residual oil that is already in the downpipe from before just burning off.
Old Oct 5, 2004 | 02:00 AM
crispydee's Avatar
Default Re: (swlabhot)
Im pretty sure the return is ok. I redid it and it is as high as it will go. The pipe into the sump touches the flange. When i took the turbo off no oil cam out of the return pipe so i dont think it is that. I thought it might just be residue but its done near 100 miles on the new seal so i would have thought it would have cleared it. What grade oil are you using? people ive spoke to seem to agree 5/40 is a little thin. Should be more like 15/50.
umair
Jul 22, 2010 06:25 AM
jtracing919
Apr 17, 2008 01:31 PM
Civicman86
Oct 14, 2006 12:18 PM
mugenhatch92
Apr 18, 2005 08:20 PM
fast94ex
Sep 29, 2004 11:15 AM
