new guy here, bov not working...
Old Sep 27, 2004 | 01:24 PM
bluels-t's Avatar
Default new guy here, bov not working...
i just put my turbo kit on my ls a couple of days ago and the bov doesnt seem to be working right. can it be too big for my set up, its a tial 50mm. when u let off the gas it seems it opens a second to late. im only running 6-7 psi. i got 2.5in piping. any suggestions would be nice, thanks
Old Sep 27, 2004 | 01:25 PM
tgreaves's Avatar
Default Re: new guy here, bov not working... (bluels-t)
Do you have a vacuum line attached to it, and is the vacuum line after the throttlebody.. Also there should be a place on the BOV to adjust the tension on the spring..
Old Sep 27, 2004 | 01:28 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: new guy here, bov not working... (tgreaves)
yea, check the vacuum source, but from what i've heard the tial is a poor performer on low boost setups due to the size of the bov.
Old Sep 27, 2004 | 01:34 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: new guy here, bov not working... (wantboost)
Yea check the vacuum source and try to loosen the tension on the spring in there.
bluels-t's Avatar
i got the vacuum line ran to regulator for now, should i "t" it into the brake booster, i didnt think u could adjust the tial bov
Old Sep 27, 2004 | 01:37 PM
wantboost's Avatar
Who is Mr Robot?
yea, brake booster is the best place to pul vacuum. the bov is non adjustable i think. its dependent on the spring inside the bov if i remember correctly
Old Sep 27, 2004 | 01:42 PM
bluels-t's Avatar
ok so now i gotta buy a new one cuz i dont wanna run much more then that, which one(s) do you guys suggest
Old Sep 27, 2004 | 01:45 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluels-t &raquo;</TD></TR><TR><TD CLASS="quote">i got the vacuum line ran to regulator for now, should i "t" it into the brake booster, i didnt think u could adjust the tial bov</TD></TR></TABLE>
I wouldnt "t" into the map sensor(if you have an external one) or the fpr for anything.. Those are things that should be ran on there own in my mind..
If you dont have a good vacuum source to your BOV then you might run the risk of leaking pressure under boost and not creating a vacuum fast enough to pull your BOV open without and compressor surge..
Just "T" your BOV into the brake booster, Or just to test it you can remove the line that goes to your PCV valve and hook the BOV vacuum line there on the manifold..
1DayIllBFast
Jul 10, 2009 06:22 AM
Dave_yd
Mar 31, 2008 09:13 AM
TurboGoKart
Jun 11, 2005 09:15 AM
a1320addict
Apr 29, 2005 06:01 PM
_Endless_
Aug 30, 2002 06:30 PM
