for guys with 600 whp....
Old Sep 27, 2004 | 12:50 PM
b00stedbyFastrax's Avatar
Default for guys with 600 whp....
what range of spark plugs are you using? currently i am running ngk 9's and the car seem to break up very bad when i make a run within 10-15 mins of the first run. it is gapped at .020". what would you guys recommend?
Old Sep 27, 2004 | 12:55 PM
PrecisionH23a's Avatar
Default Re: for guys with 600 whp.... (b00stedbyFastrax)
you could always try a 10 series plug.
do you by any chance have an ignition system other than stock on the car? which plug wires are you running?
Old Sep 27, 2004 | 01:02 PM
Default Re: for guys with 600 whp.... (PrecisionH23a)
yeah, i have a msd digital 6 with a hvcII coil and magnecor 10mm wires.
Old Sep 27, 2004 | 01:03 PM
plug wires? i like the oem NGK's personally...
Old Sep 27, 2004 | 03:11 PM
greenhotrod's Avatar
that does not sound like a plug issue.we run 9's gapped at .28 with over 700 hp.we had the same problem which turned out to be an alternator issue.
Old Sep 27, 2004 | 03:58 PM
Mase's Avatar
Default Re: for guys with 600 whp.... (greenhotrod)
9 series are fine, even 8's will probably do the trick, but i normally recommend 9's
Old Sep 27, 2004 | 04:10 PM
DRAGLS's Avatar
start with making sure all your connections are good
Old Sep 27, 2004 | 04:13 PM
SOUNDEFFECTS's Avatar
Default Re: for guys with 600 whp.... (DRAGLS)
I had 9's in mine.
Old Sep 27, 2004 | 05:15 PM
Default Re: for guys with 600 whp.... (SOUNDEFFECTS)
thanks guys. will check all connections and the alternator.
turbo gsr2000
Sep 23, 2009 06:56 AM
lilmex
Sep 28, 2007 05:31 AM
ASpec818
11
Jan 2, 2005 05:29 PM
KekeK-18
Mar 29, 2004 05:40 PM
TRE_
Jul 18, 2003 12:58 PM
