Check out my oil return...
Old Sep 27, 2004 | 01:12 PM
swlabhot's Avatar
Default Check out my oil return...
Yes, yet another oil return question....Does this look OK? As the actual fitting on the pan looks has a slight upwards angle (slight slant towards the weld). Is this going to prevent the oil from dripping back into the pan??
Old Sep 27, 2004 | 01:28 PM
RACEPAK's Avatar
Default Re: Check out my oil return... (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Yes, yet another oil return question....Does this look OK? As the actual fitting on the pan looks has a slight upwards angle (slight slant towards the weld). Is this going to prevent the oil from dripping back into the pan??
it looks kinda ghetto...
try tap it with a hammer
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
It looks like it should be ok to me. If youre too worried about it then you could take a hammer and gently tap on it to see if you could bend it up just a **** hair more. Just be sure not to break any seals or anything. But honestly i think that it would be fine.
Old Sep 27, 2004 | 01:46 PM
minivan81's Avatar
Default Re: Check out my oil return... (sCeRaXn)
Looks fine.
Old Sep 27, 2004 | 01:49 PM
11psiTurboSI's Avatar
Default Re: Check out my oil return... (minivan81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by minivan81 &raquo;</TD></TR><TR><TD CLASS="quote">Looks fine.</TD></TR></TABLE>
i agree
Old Sep 27, 2004 | 03:06 PM
greenhotrod's Avatar
it will be ok as long as the outlet on the oil return on the turbo is above the fitting on the oil pan. the angle of the fitting does not matter
SM00TH976
May 17, 2006 08:59 AM
Novtecdohc
Aug 31, 2005 04:29 PM
machine4321
Feb 11, 2005 05:15 PM
shadow103rd
May 12, 2004 11:55 AM
Steve91
May 29, 2003 08:43 AM
