Missing link and VAFC?
Old Sep 28, 2004 | 12:04 PM
BDTURBO's Avatar
Default Missing link and VAFC?
I have a 95 civic ex, Greddy turbo, 7lbs boost, sometimes when I floor it my check engine light comes on for MAP sensor, I have a VAFC but do I need a missing link also or do I just need to set my VAFC a certain way, if so what do I need to do? Thanks!
Old Sep 28, 2004 | 01:36 PM
shadow103rd's Avatar
Default Re: Missing link and VAFC? (BDTURBO)
you need to make sure its setup correctly......search on this.. there are like millions of threads
You dont need the missing link
Jon
Old Sep 28, 2004 | 01:58 PM
MooreBoost's Avatar
Default Re: Missing link and VAFC? (shadow103rd)
Are you using DSM 450's or an FMU?
Old Sep 28, 2004 | 02:21 PM
BDTURBO's Avatar
Default Re: Missing link and VAFC? (tegunderpressure)
stock injectors, with greddy blue box
Old Sep 28, 2004 | 03:59 PM
93turbo16's Avatar
ditch that blue box, get bigger injectors and run the vafc, you are probbaly turning up the VAFC making th engine throw the code on stock injectors.
Old Oct 1, 2004 | 08:04 PM
EKhothatch's Avatar
I'm having this same problem. Anybody have any other ideas. And no there isn't plenty of topics or info no this.
Old Oct 2, 2004 | 10:34 PM
EKhothatch's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">ditch that blue box, get bigger injectors and run the vafc, you are probbaly turning up the VAFC making th engine throw the code on stock injectors.</TD></TR></TABLE>
Listen to this advise. This ended up being my problem.
Old Oct 3, 2004 | 11:02 AM
MooreBoost's Avatar
Default Re: (EKhothatch)
Yeah, theres really no reason to run both, you dont need them. I would probably ditch the AFC though.
Old Oct 3, 2004 | 11:14 AM
BoostR41's Avatar
Default Re: (tegunderpressure)
people really don't understand a blue box do they? the blue box uses a voltage clamp so you don't throw the map code so I would say your box is wired wrong.
also don't just get bigger injectors and use the AFC get a FMU and bigger injectors you will have way less headaches if you set it up like that.
I am a former afc "hack" user and the FMU, 450's, afc, missing link and fuel pump are a million times better
Old Oct 3, 2004 | 11:15 AM
Blaze45's Avatar
Brrraaaap!
Default Re: (BoostR41)
VAFC users look here.... https://honda-tech.com/zerothread?id=841443
Your advancing timming ALOT right as you go into boost...
Blaze
Old Oct 3, 2004 | 05:18 PM
BoostR41's Avatar
Default Re: (Blaze45)
that is the AFC hack if you use a FMU you don't manipulate map voltage as much. I will post my setting for a rich tune later on if I can...I can tell you at idle with 450's it is leaned 50% and at 8k it is only trimmed 17% it is stepped so you don't mess with timing as much
Old Oct 8, 2004 | 06:21 PM
ChadB's Avatar
I ran the missing link and never threw a code..
Old Oct 9, 2004 | 11:44 AM
HitEm'Up's Avatar
I used a missing link when i had my turbo setup and never threw a code
Old Oct 14, 2004 | 05:01 PM
BDTURBO's Avatar
Default Re: Missing link and VAFC? (98turbohatch)
so if i get an FMU and bigger injectors I can get rid of the Greddy BLUE BOX? less headaches...but do I have to tune them...with the box i dont have to do anything.
Old Oct 14, 2004 | 10:04 PM
d15b7racer's Avatar
yes you'd need to tune if u go afc hack w/ bigger injectors....the blue box is the safest way with the stock injectors
Old Oct 15, 2004 | 12:33 AM
diputs's Avatar
Default Re: Missing link and VAFC? (d15b7racer)
Double and triple check your wiring. I know a guy that had the exact problem you are having. He put a z6 swap in, and accidentally miswired a harness wire to ground when he was installing it. It was throwing a MAP code after he would boost. MAP sensor was good, it just took him forever to find the wiring mistake. He too was running a greddy kit with the box.
Also...you don't really need bigger injectors with an FMU. What I think you are considering are the following:
blue box/stock injectors
HP pump/FMU/missing link/stock injectors
VAFC/450's....the hack
Old Oct 15, 2004 | 11:23 AM
BDTURBO's Avatar
Default Re: Missing link and VAFC? (diputs)
the wiring is right....but would it throw a code if the wiring is LOOSE? Im thinking there is a bad connection since it only thows the code every once in awhile. Not all the time..you know.
Blue00Si
24
Mar 2, 2007 07:36 PM
EvilIntegrationLS
Aug 5, 2004 12:13 PM
Hoodwinked
Oct 24, 2003 05:04 PM
Del_Slowest
Oct 8, 2003 07:08 PM
M-EJ1
Feb 14, 2003 11:34 PM
