B16 cams for turbo
Old Sep 26, 2004 | 08:12 AM
ildknyli's Avatar
Default B16 cams for turbo
Well Im building my head for turbo and was wondering would I get good results with B16 cams. Or should I wait off for some GSR Or ITR cams for better results. I have found some B16s for 60 bucks.
Old Sep 26, 2004 | 08:23 AM
Boosted2K's Avatar
Default Re: B16 cams for turbo (ildknyli)
I'm curious about this too, how big of gain is their switching from b16 to GSR bumpsticks
Old Sep 26, 2004 | 09:45 AM
JDogg's Avatar
Default Re: B16 cams for turbo (Boosted2K)
it depends on the manifold/turbo and the rest of the exhaust.
the problem is backpressure, you cant run a big cam that has alot of overlap if you have alot of backpressure... ie, small turbine, log manifold, small downpipe.. if you have that type of setup, use the smaller cams... b16
if you have the bling tubular equal length manifold with a big turbine and 3inch exhaust use the bigger cams... itr/ctr, etc.
Old Sep 26, 2004 | 12:03 PM
ildknyli's Avatar
Default Re: B16 cams for turbo (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">
if you have the bling tubular equal length manifold with a big turbine and 3inch exhaust use the bigger cams... itr/ctr, etc.</TD></TR></TABLE>
Im planning togo this direction so I should use the ITR/CTR. But if I still went the cheap way out the B16's, would the power difference be huge? Im Planning to bump at least 550 whp.
Thanks for the reply
Old Sep 26, 2004 | 02:45 PM
Boostfed's Avatar
New User
This is on my set up where I do rev high, I will eventually pull this up to 10,500. But here you go, alot of power at the same peak at 8700rpm but kept climbing after that too with ITR over 2000 Spec Si B16A cams
Old Sep 26, 2004 | 07:02 PM
22psicrx's Avatar
I have crower turbo cams and it keeps pulling all the way to redline in each gear. I run 22 psi to 8000 rpm, there is no flat spot. just pulling, duration is 272 or 292. not alot of overlap, huge difference from a stock vtec cam.
Old Sep 27, 2004 | 02:29 AM
RRL's Avatar
RRL
Default Re: B16 cams for turbo (22psicrx)
hi boostfed and 22psicrx
can i know what turbo are you using? this may be off the thread but what A/F mixture are you seeing with that high boost?
Old Sep 27, 2004 | 03:49 AM
NOSED_CRX_VTEC's Avatar
Default Re: B16 cams for turbo (RRL)
What about a set of adjustable cam pulleys
Would they do any the with the stock b16 cams
Old Sep 27, 2004 | 06:24 AM
SiKid86's Avatar
Default Re: B16 cams for turbo (NOSED_CRX_VTEC)
go for gsr's with ajustable cam gears. Check out ebay. I bought mine off some one local for 75 bux
Old Sep 27, 2004 | 10:10 PM
ildknyli's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOSED_CRX_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">What about a set of adjustable cam pulleys
Would they do any the with the stock b16 cams</TD></TR></TABLE>
I also want to know
elektronsi
Apr 29, 2008 06:33 PM
RACEPAK
Mar 23, 2006 07:48 AM
h0tsihatch
11
Sep 10, 2004 01:31 PM
SIRBoost
Jan 19, 2003 11:43 PM
ShAAdiiiNG
18
Jan 10, 2003 05:18 PM
