turbo not spooling
Old Sep 28, 2004 | 08:00 PM
99CRX-SI's Avatar
Default turbo not spooling
Just did a t3/t4 set up on my b16. brand new turbonetics turbo.
the problem is when I give it gas it jumps from 20 vacum to 0 and stays there. You can hear the turbo spooling through the exaust but not making any psi.
Its not the bov, wastegate, no leacks in the inter cooler or the piping. I took the intercooler pipe off the turbo and preassurized it with shop air and had 5 psi. I can only think that its a bad turbo but when you shoot shop air in the turbo it spools and makes preassure out of the outlet. Im running out of ideas. Any one have this problem before.
thanks dan
Old Sep 28, 2004 | 08:03 PM
adictionbass's Avatar
Default Re: turbo not spooling (99CRX-SI)
is your boost gauge installed correctly?
Old Sep 28, 2004 | 08:15 PM
99CRX-SI's Avatar
Default Re: turbo not spooling (adictionbass)
yeah it is
Old Sep 28, 2004 | 08:18 PM
Sinner's Avatar
have you checked your charge pipes for holding pressure?
Old Sep 28, 2004 | 08:24 PM
vaporboy12's Avatar
Default Re: (Sinner)
sure the vacum line are hooked up right?
Old Sep 28, 2004 | 08:32 PM
99CRX-SI's Avatar
yes and yes.
Old Sep 29, 2004 | 09:10 AM
bluesi00's Avatar
maybe ur wastegate is stuck and its letting all the boost out of the dump tube.
Old Sep 29, 2004 | 09:27 AM
paul93sir's Avatar
what kind of turbo is it?
MiMiK
Dec 10, 2005 06:21 PM
jolt-tsp
Nov 20, 2004 09:13 PM
mattcalica
May 26, 2004 11:48 PM
b00stedbyFastrax
May 11, 2004 02:55 PM
JonGP4
Jan 4, 2004 09:30 PM
