9:1 comp loses low end
Old Sep 28, 2004 | 08:24 AM
opiumdaze's Avatar
Default 9:1 comp loses low end
my b18c turbo has low comp pistons and when I launch at 3500-4000 rpm it bogs down like it is being over killed with fuel..and it seems to lost low end but when i reach 5k it starts to move.. any tips or suggestions would be appreciated
Old Sep 28, 2004 | 08:45 AM
m R g S r's Avatar
Default Re: 9:1 comp loses low end (opiumdaze)
Your turbo probally doesn't spool until 5000rpm. Also, unless you have something to build boost at the line, you are really not spooling the turbo by putting a light load on it (aka revving the engine).
Old Sep 28, 2004 | 08:58 AM
86si's Avatar
launch higher and use your rev limiter to build boost
Old Sep 28, 2004 | 09:31 AM
opiumdaze's Avatar
launchng 5000k and up will make me burn out and go no where. plus my tires dont hook that great..any other suggestions?
Old Sep 28, 2004 | 11:32 AM
JDogg's Avatar
Default Re: (opiumdaze)
ever heard of slipping the clutch
Old Sep 28, 2004 | 12:39 PM
opiumdaze's Avatar
ive done that..doesnt help
Old Sep 28, 2004 | 12:46 PM
mrx's Avatar
mrx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze &raquo;</TD></TR><TR><TD CLASS="quote">ive done that..doesnt help</TD></TR></TABLE>
i have the same problem with my b16 with stock compression (10,2:1) i think it has something to do with the turbo itself (because the turbo is a resistance in the exhaust system until it began to spool) and the second thing i think is because of the tuning... i have the same problem with a perfect a/f ratio but under 3krpm the car feels like i hit a brick wall, after 3krpm it is fast as hell...
when my clutch is fixed then i will experiment with the timing and the fuel and see if it gets better... but maybe someone has allready experience with this phenomen.
Greets
Malte.
Old Sep 28, 2004 | 02:18 PM
iiilgsrlll's Avatar
Get a 2-step
Old Sep 29, 2004 | 03:20 AM
ZoRG's Avatar
Default Re: (mrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">
Greets
Malte.</TD></TR></TABLE>
Define spool ... its always a restirction btw, and its also always "spooling" unless you switch the car off.
The car should pull just fine even with 9:1 should not be the end of the world.
Old Sep 29, 2004 | 03:29 AM
Adi Radoncic's Avatar
On Fire!
Default Re: (ZoRG)
I'm willing to bet that both of you guys have your cars over fueled just before the turbo comes in, than once it spools up it pulls like crazy..
Am I right?
You need to be running pritty lean just before you start to spool (14's afr) that way your matched up once the turbo spools up and feels like a factory turbo car.
If you have problems launching at that low of rpm's its time for some tires, traction bars, LSD.
Old Sep 29, 2004 | 03:34 AM
mrx's Avatar
mrx
Default Re: (newgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">I'm willing to bet that both of you guys have your cars over fueled just before the turbo comes in, than once it spools up it pulls like crazy..
Am I right?
If you have problems launching at that low of rpm's its time for some tires, traction bars, LSD. </TD></TR></TABLE>
Hallo,
i have a afr from about 15-14,2:1 before boost kicks in. so i think it is not extreamly to lean and not extremly too rich. so i think maybe it has something to do with the ignition timing, maybe i need a bit more advance in this area... but i will recheck that when i clutch is fixed.
with spool i mean that the turbo spools so fast that he is able to build boost.
i think a turbo that not builds boost is definitive a blocking device instead of a clean NA exhaust system or am i wrong?
what is with the back pressure from the exhaust system? i have a exhaust system with nearly no back pressure, maybe thats the reason for the bad NA response of the engine?!
Greets
Malte.
Old Sep 29, 2004 | 03:41 AM
JDogg's Avatar
Default Re: (mrx)
exhaust restriction has nothing to do with it....
imo you need to do 2 things
learn to drive
get it tuned
i have driven/tuned many setups, some just dont like to run below a certian rpm.. take off at a higher rpm while slipping the clutch, if that dosnt work get some better tires.
Old Sep 29, 2004 | 05:44 AM
Johnyquest's Avatar
Default Re: (JDogg)
If you dropped the compression, you need to add a bunch of timing down there to make up for it or it's going to feel like a dog. Who did your tuning / what are you running ecu wise? chipped?
Matt
jdm j
Honda S2000
Jan 31, 2008 08:27 AM
JSiRTO
Oct 9, 2006 04:22 PM
EKB18BPR3
Jun 1, 2004 02:05 PM
boostlee
Jan 28, 2004 09:38 AM
Boostage
Nov 28, 2003 02:29 PM
