JRSC BTC and MAP controllers
Old Sep 28, 2004 | 05:14 PM
cvclover's Avatar
Default JRSC BTC and MAP controllers
On a 99 Si
At 8 psi
Would the JR BTC and MAP controllers be safe enough? I wont have any CEL lights correct? Do I NEED the MAP controller to be CEL free?
Where can I get a good deal on a BTC?
Also are the stock injectors going to be enough?
I wont be going any higher than 8 psi
Old Sep 29, 2004 | 03:11 AM
cvclover's Avatar
Default Re: JRSC BTC and MAP controllers (cvclover)
Bump
Old Sep 29, 2004 | 12:20 PM
cvclover's Avatar
Is the JR BTC and MAP going to be all I need to control fuel?
Old Sep 29, 2004 | 12:27 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvclover &raquo;</TD></TR><TR><TD CLASS="quote">On a 99 Si
At 8 psi
I wont be going any higher than 8 psi</TD></TR></TABLE>
you will need an FMU along side with these. Im guessing the map controller is basically like a missing link set up so with that on it blocks the map from seeing boost when you boost. the BTC is a boost timing controller and it pulls timing under boost. it is better then nothing lets put it that way. But i would realy reccomend you look into hondata or uberdata. It will take care of all those things, you just will need to upgrade fuel injectors to larger ones.
Brandenvtec719
Apr 11, 2018 06:58 PM
rorik
Jan 23, 2006 06:27 PM
hondaeg8
Jul 29, 2005 07:41 PM
vipps
Jul 27, 2005 08:56 AM
GreddySi99
Mar 17, 2003 03:15 PM
