Jackson Racing Supercharger help!!!!
Old Sep 28, 2004 | 07:26 AM
Triscuit's Avatar
Default Jackson Racing Supercharger help!!!!
Hi im having a problem with my Jackson Racing SC for a B16A2. When the car is on the boost gauge shows -10 instead of -20 vaccum. Is their a hose switched or do I have a vaccum leak? When I try to go into boost it studders and wants to die. I have an upgraded walbro 255 fuel pump, 450 dsm blue tops, and running uberdata. Please point me into the right direction of the problem. Thanks in advance.
Old Sep 28, 2004 | 07:53 AM
Triscuit's Avatar
I'm wondering if I have all the connectors installed?
Old Sep 28, 2004 | 07:55 AM
RacerXI's Avatar
Default Re: (Ronin EG6)
Did you just install the blower/injectors/uberdata? Or did it run ok before the uberdata install?
Old Sep 28, 2004 | 08:13 AM
Triscuit's Avatar
It ran good before but uberdata was always running. I think i might have either connectors switched or a vacumm leak. Maybe my belts are to tight thats why its at -10 vac instead of -20 at idle.
Old Sep 28, 2004 | 08:16 AM
toolowsol's Avatar
belts wont matter. You have a vacuum tube off or some sort of a check valuve or one way valve on backwards is my guess.
Old Sep 28, 2004 | 08:47 AM
Triscuit's Avatar
so my vaccum lines could be on wrong?
Old Sep 28, 2004 | 09:35 AM
Triscuit's Avatar
bump for help!
Old Sep 28, 2004 | 10:38 AM
Triscuit's Avatar
could a vaccum leak have the vaccum to -10 instead of -20 at idle?
Old Sep 28, 2004 | 03:33 PM
Triscuit's Avatar
will a messed up throttle body gasket give me a vaccum leak that raises my negetive vaccum to -10 instead of -20 at idle......please someone help a noob out. I've searched already
Old Sep 29, 2004 | 03:01 AM
Triscuit's Avatar
this is a help bump!
Old Sep 29, 2004 | 12:49 PM
Triscuit's Avatar
would a new throttle body gasket cancel my vaccum leak?
Old Sep 29, 2004 | 02:49 PM
supercharged98's Avatar
could be if it was bad or on upside down. i had a bad vacuum leak and replaced the throttle body gasket and that fixed everything. check to make sure you have a check valve on your brake booster and your vacuum lines all hooked up, and all bolts tightened connecting supercharger, goose neck, and so on. and as far as having vacuum lines switched, as long as all your vacuum lines are connect to a port, it doesnt matter which one you have them hooked up to.
Old Sep 29, 2004 | 03:37 PM
The-LS's Avatar
Default Re: Jackson Racing Supercharger help!!!! (Ronin EG6)
tell us again what you have in your car when it ran fine, and then what you changed before the problem come up. Sounds like a vac leak
Old Sep 29, 2004 | 05:17 PM
Triscuit's Avatar
I had a b16a2 with everything else thats on right now except the new 450 dsm injectors. I took off the throttle body to reach somethingso when i was taking it off i could have porbably wripped the gasket.
Old Sep 29, 2004 | 06:01 PM
The-LS's Avatar
well if you think you have a damaged gasket check that first. I'm assuming you've been running Uberdata fine without problems before this. If you just put in new 450 DSM inj. what inj were you running before and did you change your Uberdata map to run with the new 450cc inj under boost? You can also have a vacuum leak around the new DSM injector(s), check that out while you are doing the TB gasket.
Old Sep 29, 2004 | 06:23 PM
Triscuit's Avatar
wow never knew you could have a vaccum leak around the injectors yea I scaled the map for 450 inectors in unberdata I just need a day off to see if it is the tb gasket thanks for you help.
Old Sep 29, 2004 | 07:39 PM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ronin EG6 &raquo;</TD></TR><TR><TD CLASS="quote">wow never knew you could have a vaccum leak around the injectors</TD></TR></TABLE>
yea you can, its just like any part that bolts to the manifold... it needs good seal. My buddy had a leak around his inj before because he had the wrong inj. and the gasket/grommet wasn't big enough to seal.
Old Sep 29, 2004 | 08:20 PM
prestonpark's Avatar
Default Re: (Black-LS)
was the 450 inj tuned
and should be ar 20 at idle
make sure u tigten the blower to the manafold tite
Old Sep 30, 2004 | 05:50 AM
Triscuit's Avatar
I never took the blower off the head so its either the tb gasket or my injectors need to settle so they would seal. Thanks for the info
jdmrex90si
May 13, 2008 10:33 PM
Whiteintegra
May 22, 2007 04:00 PM
DeDonDeRosa
Dec 3, 2005 07:54 PM
94jaxgsr
Jul 20, 2003 08:16 PM
OPTIMUS
Sep 11, 2001 10:56 AM
