What are your SC61/B18C1 setups making @ low boost?
Old 09-27-2004, 10:06 AM
*Boostwerks*'s Avatar
Default What are your SC61/B18C1 setups making @ low boost?
- I'm just wondering how much power you guys are making @ low boost (9-11psi) with this turbo?
- What engine are you running, and what CR?
- And I am also wondering how much timing your running @ full boost?
Just a little worried about how much power I am making @ 9psi with a T4/SC61 and 2.0L GSR... :/. Trying to figure some things out.
Old 09-27-2004, 10:08 AM
Chip's Avatar
Default Re: What are your SC61/B18C1 setups making @ low boost? (Bryson)
I know there was a guy on here maybe a year or two ago that made 380 WHP at 9 psi on a 10:1 83MM GSR motor.
Old 09-27-2004, 10:35 AM
m3bluegsr's Avatar
Default Re: What are your SC61/B18C1 setups making @ low boost? (Chip)
I made 302/220tq at 7200 on a stock bore gsr. this is at about 8/9 psi
9.5 to 1 comp
drag manifold
edelbrock im
3in open downpipe
only was revved to 7200 because of creep issues with the drag manifold
a/f was in the 11's and i havent seen the timing maps
Old 09-27-2004, 12:35 PM
Hrmmm
I trapped 108, and my car weighs 2350 with me in it. According to the HP calculations I was making around 250hp to the wheels.
The base map is currently running 20 degrees @ 9psi.
Old 09-27-2004, 12:48 PM
m R g S r's Avatar
Default Re: (Bryson)
When are you getting it tuned? Is it just a base map, (that may be the problem) or is it tuned, just not fully tuned?
Old 09-27-2004, 01:31 PM
XXXRacing's Avatar
Default Re: (m R g S r)
might not help at all but ran 10.19 on 81mm gsr, 9.0:1 compression on 26 lbs. Never had it on a dyno though. Trapped in the mid 140s.
Old 09-27-2004, 01:40 PM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">When are you getting it tuned? Is it just a base map, (that may be the problem) or is it tuned, just not fully tuned?</TD></TR></TABLE>
i agree here
Old 09-27-2004, 02:00 PM
AFR is 10-12:1 and isn't very flat, but what I've learned is that the AFR doesn't impact HP very much at all.
The timing is about right from what I've seen.
Based on those two factors, I'm not so sure its the "tuning", however that of course has to be part of it.
Old 09-27-2004, 02:09 PM
Oh...
one thing I have to add, is that I'm @ 5800ft so the correction factor also comes into play.
Old 09-27-2004, 02:15 PM
toolowsol's Avatar
stock jdm gsr, SC34 turbo at 7.5psi, 290whp with skunk2 mani and 64mm TB.
12.0-11.5 AFR, total timing at 24degrees
Old 09-27-2004, 03:17 PM
Chip's Avatar
5800 feet in elevation can easily account for a 20-25% loss in power. For example, my old car was a 5.0 mustang with a couple bolt on parts, dynoed it at 5400 feet. Uncorrected? 182 RWHP. SAE Corrected? 230 RWHP. If you get the same kind of correction factor I did, that 250 WHP becomes 315 WHP SAE, sounds on par for 9 PSI from an SC61 without a lot of tuning.
Old 09-27-2004, 03:32 PM
Killer_B's Avatar
too many variables. this post is a waste of time and space.
Old 09-27-2004, 03:41 PM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">- I'm just wondering how much power you guys are making @ low boost (9-11psi) with this turbo?
Just a little worried about how much power I am making @ 9psi with a T4/SC61 and 2.0L GSR... :/. Trying to figure some things out. </TD></TR></TABLE>
Why the T4/SC61 on such low boost? Do you plan on boosting more in the future? The #'s sound about right when corrected.
Old 09-27-2004, 03:48 PM
AlphaKennyWun's Avatar
Default Re: (Killer_B)
I didnt make a whole lot of power with the sc61 @ 14 psi (see sig)
I was hoping for 350 hp+
its a B18c stock bore
Im adding some new parts and going to go back for more tuning
some factors that are possibly hurting me now are:
conservative tuning at around 10.5 a/f (looking go 11-12 a/f)
2.5 dp - 2.25 exhaust (will change to a 3" soon)
stock tb (may bore to 64 mm or go larger)
stock im (may go with a Victor X)
slightly lower than 9:1 comp (staying same)
mbc (will go with a profec b)
tiny air filter in front of radiator fan blowing hot air on it (already went to a cold air 3" airfilter)
For now im looking to make 350 hp with just a 3" exhaust, new air filter and more tuning, same boost level.
Good luck with your goals
Old 09-27-2004, 04:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killer_B &raquo;</TD></TR><TR><TD CLASS="quote">too many variables. this post is a waste of time and space. </TD></TR></TABLE>
You should kill your-self.
I was just trying to scope out the field to see how much power people were making @ low boost, so I can see how I compare.
TurboChrgd_Civic... I was just running so low boost because I don't have a 3bar sensor yet, and because I will gradually increase boost when I dyno the car.
So I guess the car is running alright from the responses so far. As soon as I get a 3bar map sensor, I will be heading to the dyno and tuning for 25psi.
Old 09-27-2004, 11:01 PM
devoid's Avatar
i wouldn't worry about it considering the altitude factor..
@ 25psi you should be able to hit around 450 uncorrected..
Old 09-27-2004, 11:22 PM
Sonny's Avatar
Bryson: When I was in Colorado, the car I had ran like ****! You gotta factor in the altitude man. The car (Lancer) felt ok at the airport (5000 ft), but when I was up near Cripple Creek (10,000 ft), I thought I was gonna have to get out and push.
Sonny
Old 09-28-2004, 07:35 AM
Cool...
I'm just anxious to dyno the car to truely find out how much power I'm making...
Hows the R1 Sonny?
Old 09-28-2004, 08:00 AM
turbo*s2k's Avatar
Good luck. Let us know what kind of #'s you put down!
Old 09-28-2004, 08:16 AM
b18cx's Avatar
Default Re: (TurboChrgd_Civic)
Bone stock JDM GSR (10.6:1) with injectors and Hondata. SC61. 9-9.5 psi on pump gas. 320 whp. Ran consistant 11.40's.
Old 09-28-2004, 02:38 PM
Default Re: (b18cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">Bone stock JDM GSR (10.6:1) with injectors and Hondata. SC61. 9-9.5 psi on pump gas. 320 whp. Ran consistant 11.40's.</TD></TR></TABLE>
Some times I wish I was at a much lower altitude...
Old 09-28-2004, 03:17 PM
Sonny's Avatar
R1 is badass...modding it is addicting.
Anyway, I remember seeing some dyno charts from some Colorado peeps and the dyno had a correction factor of like 1.25 or 1.3, I think? If you were conservative and said 1.25 on 250 whp, that would put you at 313 whp at sea level.
Sonny
Old 09-29-2004, 05:17 AM
cinq's Avatar
You can get pretty good numbers depending on the stuff you put on. Here is mine.
https://honda-tech.com/zerothread?id=848005
You guys are good drivers...I don't know how your get so low E.Ts like that.
I ran best with street tires at 13.4sec @117mph.
Old 09-29-2004, 11:17 PM
Kwuaymaikrup's Avatar
Default Re: What are your SC61/B18C1 setups making @ low boost? (cinq)
420@11psi here. Engine is 84.5mm, 9:1.
Modified by Kwuaymaikrup at 12:26 PM 9/30/2004
Old 10-06-2004, 09:40 PM
92SleepyHB's Avatar
Default Re: What are your SC61/B18C1 setups making @ low boost? (Kwuaymaikrup)
Makin 402whp&gt;265trq&gt;@10psi
Ls/Vtech 85mm + 10:5:1
Hiboost 2.0
04-17-2013 08:14 PM
95 civic turbo_gsr
05-06-2008 07:47 PM
gsrtpower
07-24-2007 04:44 AM
civic_66
02-14-2007 07:22 AM
f1 vtec
11-01-2004 09:38 PM
Quick Reply: What are your SC61/B18C1 setups making @ low boost?
