breather
Old Sep 26, 2004 | 06:56 AM
darkirony's Avatar
Default breather
my kit is about to go on and was just curious or not to see if i needed a breather on the valve cover or not. or should i just run a line to the piping
Old Sep 26, 2004 | 07:15 AM
DRAGLS's Avatar
Default Re: breather (darkirony)
I keep mine open, nothing comes out
Old Sep 26, 2004 | 08:21 AM
Boosted2K's Avatar
Default Re: breather (DRAGLS)
Atleast put a filter on it, they are cheap at autozone. If you wanna do it right, check this out for the PCV system.
http://www.beesandgoats.com/bo...l#Oil
Or run the Endyn setup, thats what I use (www.theoldone.com) under components
Old Sep 26, 2004 | 01:52 PM
DRAGLS's Avatar
Default Re: breather (Boosted2K)
so what does the filter do? just hook up a hose and run it to the bottom of the car!
Old Sep 26, 2004 | 02:02 PM
Boosted2K's Avatar
Well, their is vaccum created at the valve cover on a honda
Old Sep 26, 2004 | 02:04 PM
DRAGLS's Avatar
oh ya go turn your car on and tell me what you feel at the valve cover port
Old Sep 26, 2004 | 02:26 PM
Boosted2K's Avatar
Well, if you think about it on a honda N/A their is vaccum created at the vave cover from the intake pipe to help vent the motor. And their is vaccum created on the PCV valve from the intake manifold to vent the crankcase. When boosted the boost pressure will hold the PCV valve shut and pressurize the crankcase. This pressure has no place to go except up past the rings and out the little tube on the valve cover (blowby).
The proper way to do it is vent both the crankcase and valve cover to a catch can and provide a vaccum source pre-turbo to pull out the vapors. Or put a small filter on the valve cover and vent the crakcase directly from the freeze plugs on the back of the block and eliminate the PCV system.
Oh yeah, thanks for the attitude "genius" but I've probably been doing this longer than you
Old Sep 26, 2004 | 02:32 PM
DRAGLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">oh ya go turn your car on and tell me what you feel at the valve cover port</TD></TR></TABLE>
exactly what I was saying there is no vaccum at the valve cover there is blowby coming thru it! ya ok your honda is probably the first car you have had
Old Sep 26, 2004 | 02:35 PM
Boosted2K's Avatar
I'm not here to argue, this topic has been cover 1000 times. Do a search
Old Sep 26, 2004 | 07:37 PM
darkirony's Avatar
cool thx, i just bought one
Dm914
19
May 29, 2015 10:49 AM
fryman
Apr 3, 2013 04:12 AM
Prelude91siT
Jan 1, 2004 10:42 AM
zilverz
May 31, 2002 01:09 PM
fiebru1119
Feb 19, 2002 05:34 AM
