Inline Pro Head Gasket On B Series
Old Sep 27, 2004 | 07:05 AM
Power Rev Racing's Avatar
Default Inline Pro Head Gasket On B Series
http://www.inlinepro.com
I have seen there ad in magazines long time ago, and i remember them claiming that with their head gasket, and your stock motor, you will be able to turn up the boost on with good tuning to about 400 hp. I don't beleive it, but has anyone ever tried using there head gasket on a stock motor? If so, how much hp have you made with it?
I personally dont see how a head gasket can make you stock pistons, and rods be able to handle the pressure of 400hp.
Old Sep 27, 2004 | 08:02 AM
Gravy's Avatar
Default Re: Inline Pro Head Gasket On B Series (Power Rev Racing)
stock b series have gone past the 300whp mark. why not just go with a cometic hp to lower compression. or even a custom thickness from cometic.
Old Sep 27, 2004 | 08:08 AM
FOrSfEd's Avatar
Default Re: Inline Pro Head Gasket On B Series (Gravy)
there have been numerous inlinepro people and people on this board that have used that headgasket on stock motor and made over 400hp
Old Sep 27, 2004 | 08:32 AM
Default Re: Inline Pro Head Gasket On B Series (FOrSfEd)
I already just about hit the 300 hp mark. I want to get to about 400hp now. I am just searching around looking at different ways to acheive it.
Old Sep 27, 2004 | 08:37 AM
88crxb16a's Avatar
I have this gasket on my car. We are looking for 350-400 whp. The gasket is throwing my timing off. I;ve seen some cars with serious whp with this gasket. Tunned right it should last for a long time
Old Sep 27, 2004 | 09:05 AM
Default Re: Inline Pro Head Gasket On B Series (88crxb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxb16a &raquo;</TD></TR><TR><TD CLASS="quote">I have this gasket on my car. We are looking for 350-400 whp. The gasket is throwing my timing off. I;ve seen some cars with serious whp with this gasket. Tunned right it should last for a long time</TD></TR></TABLE>
Your looking to get 350 -400 hp? So you have not actually put it on the dyno yet? How much boost are you running, and on what turbo?
Thanks
Old Sep 27, 2004 | 09:39 AM
TurboJesse
Guest
Posts: n/a
You want to make 400whp on a stock block and can't figure out how/why your timing is off?
Old Sep 27, 2004 | 09:41 AM
TurboJesse
Guest
Posts: n/a
Default Re: Inline Pro Head Gasket On B Series (Mpir3)
BTW: i used to run the gasket on my stock b16a....made ~315WHP on pump gas with the 450cc injectors maxed out. I had planned to run 550's and 350-365 was teh goal on race gas (550cc's took a **** on me though). Race gas is VERY important in a thick headgasket setup due to how the gasket effects teh quench area.
Old Sep 27, 2004 | 12:53 PM
88crxb16a's Avatar
percision turbo 60 trim .63 ar, Persicon 880cc injectors, inline pro fuel pump, inline pro 3mm head gasket, spearco fmic that can handle up to 600 hp, 3" down pipe to 3" exhaust, 38mm turbo smart wastegate, turbo smart bov, hondata s200, inline pro t3 turbo manifold. Thats just bout everything. Gonna tune it at 12psi for the street. Gonna run 18psi on the track with race gas and want like 350whp.
Old Sep 27, 2004 | 01:02 PM
YashiMotors's Avatar
what engine is it?
I'm going to use inline pro headgasket on my stock type r engine. But i'm not going to push it more than 250-260hp. On 0,5 bar that is 7,5 PSI
Old Sep 27, 2004 | 01:03 PM
88crxb16a's Avatar
Default Re: Inline Pro Head Gasket On B Series (YASH)
jdm b16a1
Old Sep 27, 2004 | 01:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxb16a &raquo;</TD></TR><TR><TD CLASS="quote">jdm b16a1</TD></TR></TABLE>
aight...what was your compression before and after the inlinepro gasket?
Old Sep 27, 2004 | 01:25 PM
88crxb16a's Avatar
was 10:2:1 Now is should be 9:5:1 or 9:1 Don't know excatly have had a chance to get it tested yet
Power Rev Racing
Sep 27, 2004 09:00 AM
riceball777
May 17, 2004 07:10 PM
SloRSTeg
Sep 30, 2003 07:59 PM
DarkSubRosa
Mar 19, 2003 03:25 PM
schwett
Apr 18, 2002 04:19 PM
