Crankcase Ventilation
Old Sep 29, 2004 | 08:10 AM
Boosted_92's Avatar
Default Crankcase Ventilation
Another member posted the following pic:
Can someone explain to me how to route this setup and what the pros and cons are of doing this? (This is a great looking setup btw)
Thank you.
Old Sep 29, 2004 | 08:12 AM
m R g S r's Avatar
Default Re: Crankcase Ventilation (Boosted_92)
Can you search? Both those lines go to a catch can, and there are a few pros to doing this.
Old Sep 29, 2004 | 08:22 AM
FlySi's Avatar
Default Re: Crankcase Ventilation (m R g S r)
id like to know 2... but am also 2 much of a lazy bastard to search
Old Sep 29, 2004 | 09:07 AM
Boosted_92's Avatar
I don't understand why people say search. If I could have found it I wouldn't have posted.
I know that the lines run to a catch can but was wondering if anyone had more detailed pics of the engine bay.
I know there must be Pros and Cons to this setup. I would like to know what they are. Not there may be some pros to running a setup like this.
There are Pros to paying for a hooker but that doesn't mean I am going to do it without looking at the negative side.
Old Sep 29, 2004 | 09:20 AM
Sprockets's Avatar
If I stood on my car like that, my fat *** would break something!
You might have better luck getting an answer to your question on the Endyn forums.
http://www.theoldone.com/forum...t.asp
Old Sep 29, 2004 | 10:24 AM
RyanEJ8's Avatar
Dasher did a thread on this awhile back. Search under PCV in the Forced Induction forum.
Old Sep 29, 2004 | 11:43 AM
4_door_teg's Avatar
Default Re: Crankcase Ventilation (RyanCivic2000)
Look at the PCV section of this guide, tons of good info
http://www.beesandgoats.com/bo....html
Old Sep 29, 2004 | 12:15 PM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_92 &raquo;</TD></TR><TR><TD CLASS="quote">
This is a sick looking setup.
Old Sep 29, 2004 | 12:32 PM
Squirtle's Avatar
NIce sandals! But even nicer motor.
Old Sep 29, 2004 | 01:01 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
nice C.O.P. settup i beleive this is a white del sol there was a thread on the build up..from the owner a while back..(t78)..
Old Sep 29, 2004 | 01:18 PM
Boosted_92's Avatar
Default Re: Crankcase Ventilation (bruceleeroy)
You are correct sir. I took it from a post by overrev90ef. I believe it was in the welding and fabrication section.
Modified by Boosted_92 at 4:43 PM 9/29/2004
Old Sep 30, 2004 | 09:20 PM
SYD's Avatar
SYD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_92 &raquo;</TD></TR><TR><TD CLASS="quote">You are correct sir. I took it from a post by overrev90ef. I believe it was in the welding and fabrication section.
Modified by Boosted_92 at 4:43 PM 9/29/2004</TD></TR></TABLE>
yeah i just saw that one but i believe there was an older one too..
Old Oct 1, 2004 | 06:19 AM
B18C1CYA's Avatar
check this thread out https://honda-tech.com/zerothread?id=986393
Old Oct 1, 2004 | 08:30 AM
White Smoke's Avatar
i my honda
Global Mod
That manifold is just outragous
Lovin the cbr coils, I cant wait till I get my setup
Old Oct 1, 2004 | 08:45 AM
AF-b16a1's Avatar
Default Re: Crankcase Ventilation (si2die4)
thats my friends setup...its a sick *** setup...he cutom made his own mani and ish..the turbo is as big as my head hahaha...he just dynoed and tuned it a couple days ago...but dont know results
Old Oct 1, 2004 | 09:46 AM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">That manifold is just outragous
Lovin the cbr coils, I cant wait till I get my setup </TD></TR></TABLE>
Don't mean to highjack the thread but does anyone have more info on the coil on plug setup?
Old Oct 1, 2004 | 12:37 PM
dornon13's Avatar
Default Re: Crankcase Ventilation (iiilgsrlll)
what kind of intake manifold is that i gotta get one of those
Old Oct 1, 2004 | 12:51 PM
MidShipCivic's Avatar
No benefit to that unless you have a pump or a dry sump.
The OEM hole does fine.
Old Oct 1, 2004 | 01:40 PM
LBR92DA-T's Avatar
its an AIR/endyn intake manifold.. it goes for like $1500
Old Oct 1, 2004 | 01:56 PM
m R g S r's Avatar
Default Re: (MidShipCivic)
How are you gonna say there is no benefit? It is relieving extra crankcase pressure, instead of trying to vent the valvecover through the tiny stock hole.
Old Oct 1, 2004 | 02:35 PM
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">How are you gonna say there is no benefit? </TD></TR></TABLE>
like this : THERES NOT BENEFIT IT's NOT LIKE YOUt GETTING SUPER ULTIMATE RING SEAL!
The OEM hole routed to the intake pipe (after a catch can) will do fine.
Old Oct 1, 2004 | 03:37 PM
Blaze45's Avatar
Brrraaaap!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
The OEM hole routed to the intake pipe (after a catch can) will do fine.</TD></TR></TABLE>
Do you have any idea what kind of pressure builds up in there? It doesnt just ventilate oil vapors, its also vents a TON of pressure that builds up. On high performance engines, the stock system is not efficent enough at displacing the pressure build up.
Old Oct 1, 2004 | 03:39 PM
Default Re: (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">
Do you have any idea what kind of pressure builds up in there? It doesnt just ventilate oil vapors, its also vents a TON of pressure that builds up. On high performance engines, the stock system is not efficent enough at displacing the pressure build up. Shut up before you post.
Bitch you shutup
2 holes and some steel braided hose to a can is an effective system for highperformance? ROFL.
Show me some damn dyno sheets. Most effective way is a dry sump .
Modified by MidShipCivic at 4:50 PM 10/1/2004
roc0487
Sep 4, 2012 07:26 AM
ericstambaugh07
Jun 15, 2007 07:41 AM
blackrag
Suspension & Brakes
Mar 1, 2007 11:01 PM
integmester
19
Jul 23, 2006 05:24 PM
