Boost finally got me.....
Old Sep 26, 2004 | 07:45 PM
ExVtec's Avatar
Default Boost finally got me.....
Just got my car tuned and have been happy with it. Well lately I have been noticing oil leaking out my valve cover breather. I replaced the tube with the little filter that sticks directly on the valve cover. Anyway, it has been slowly leaking out. I figured the filter has become saturated and started leaking. Well tonight after a few spirited runs with a friend, my intake manifold has oil laying on it. Seems to be getting alot worse. Also I could see smoke coming out the breather while it was idling...I was almost a quart low from the loss of oil under WOT....?
So I am assuming my rings are causing blowby?
Any help suggestions, anything?
Old Sep 26, 2004 | 07:50 PM
turboteg2nv's Avatar
Default Re: Boost finally got me..... (ExVtec)
sounds like blowby, but I'm not expert....run a compression test and let us know the #'s
Old Sep 26, 2004 | 07:58 PM
dunkd's Avatar
time for a compression/leakdown check
Old Sep 26, 2004 | 08:10 PM
ExVtec's Avatar
Default Re: (dunkd)
I did that...all the cylinders checked out great.....I ordered a catch can....maybe thats all it is....
Old Sep 26, 2004 | 09:08 PM
SiRkid's Avatar
Default Re: (ExVtec)
no. if you see it while idling you= fooked.
tis blowby.
and you shouldnt be losing that much oil that quickly.
afc hack sucks
time for another stock bottom end or some forged internals.
Old Sep 26, 2004 | 09:38 PM
ExVtec's Avatar
Default Re: (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">no. if you see it while idling you= fooked.
tis blowby.
afc hack sucks
time for another stock bottom end or some forged internals.</TD></TR></TABLE>
My compression comes back fine, and it runs so strong. It looks like the rings would be toast, but I would think the car would run bad and or my compression would be really down....??
Old Sep 26, 2004 | 10:04 PM
Street Ghost's Avatar
Get yourself a catch can and use that to get rid of your stock PCV system.
Old Sep 27, 2004 | 12:05 PM
ExVtec's Avatar
Default Re: (JDM Ninja)
How do I route the intake breather setup into the pcv system ?
If I completly remove the pcv setup..confused?
Old Sep 27, 2004 | 10:32 PM
ExVtec's Avatar
bump for info?
Old Sep 27, 2004 | 11:32 PM
808b18c1boosted's Avatar
Its prob your ring lands cause my car does the same ****. But my comppression sucks. 120 in 1-3 cyl and 45 in #4 and I still drive my car every day. I even ran the valve cover breather under my car with a hose from homedepo to stop the blowbye smoke from killing me. blowbye=badass buildup
Old Sep 29, 2004 | 12:43 PM
ExVtec's Avatar
Default Re: (808b18c1boosted)
If thats the case...that sucks.....I hope to get the catch can on tonight....
Old Sep 29, 2004 | 01:05 PM
maxpsi's Avatar
Are you sure you did the compression check right? It sure does sound like ringlands. It can run fine with the ringlands cracked also. You are definately getting blowby though, so solutions other than a catch can should be sought.
Old Sep 30, 2004 | 03:53 PM
ExVtec's Avatar
Default Re: (maxpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxpsi &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you did the compression check right? It sure does sound like ringlands. It can run fine with the ringlands cracked also. You are definately getting blowby though, so solutions other than a catch can should be sought.</TD></TR></TABLE>
Well tonight it DIED. Must have completly went out. So I am gonna tear into it this coming week and see whats up.
Well see.....
Old Sep 30, 2004 | 03:55 PM
maxpsi's Avatar
Good luck, bud. Post up if you need any help. God knows we've all been down that road. lol
Old Sep 30, 2004 | 05:02 PM
CRX_1.8T's Avatar
bump to help this guy get some advice...
Old Sep 30, 2004 | 05:22 PM
turbosi03's Avatar
Default Re: (CRX_1.8T)
yeah its probably your ringlands... compression test doesnt tell if the ringlands are bad or not because when I blew my stock motor only one cyl (#3) had low compression, the other three were fine...
when I pulled the head and pistons out, all of the ringlands were broken. the worst one was cyl #4...
sounds like your ringlands were cracked but you kept driving it, then they finally broke off the piston and now you may have scared cylinder walls...
time for a kick *** build up
Old Oct 6, 2004 | 04:49 PM
ExVtec's Avatar
Default Re: (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">yeah its probably your ringlands... compression test doesnt tell if the ringlands are bad or not because when I blew my stock motor only one cyl (#3) had low compression, the other three were fine...
time for a kick *** build up </TD></TR></TABLE>
I found another car....friend gave it to me....I put some belts did the basic mantenice and now it runs...so here as soon as I can...gonna pull the head and see whats up...
I figure while I have the head off, I will be getting new pistons/rods.
Anyone have any advice on the brand and where to get em....?
Price is important...being in school I don't have alot of cash....
Thanks guys...appreciate it....
jdmtiiteyo
Jan 1, 2008 06:40 PM
lilintegra25
Apr 3, 2007 05:20 PM
IloveNewt
Jan 21, 2004 10:13 PM
bigstatik
Jul 18, 2003 02:04 PM
