Brake booster for vacuum source
Old Sep 28, 2004 | 02:02 PM
XxRoCkMaNxNEOxX's Avatar
Default Brake booster for vacuum source
i have been searching and trying to see which would be the best vacuum source. i have a GE vacuum manifold. it seems like the best is from the brake booster. Everyone is saying to tap it after the check valves i assume its the grey looking thing. but when looked under the hood i couldnt find that grey looking thing(check valves)? here is the pic that i saw.
if i dont have one what would be the next suggestion for a vacuum source. ill try to get pics of my engine bay.
Modified by XxRoCkMaNxNEOxX at 5:28 PM 9/28/2004
Old Sep 28, 2004 | 02:14 PM
gritsak's Avatar
Default Re: Brake booster for vacuum source (XxRoCkMaNxNEOxX)
a vacume source for what? a vacume box or just a single thing?
people use the brake booster for a vacume box because the big line serves as a good pressure source when you have multiple things that need to see vacume/pressure..but if you are just tapping into it for say a boost guage or something just "t" into another vacume line such as the one going to the FPR
Old Sep 28, 2004 | 02:25 PM
Default Re: Brake booster for vacuum source (gritsak)
i have a GE vacuum manifold but when i looked under my car i didnt see the check valves. is it the grey thing in the pic?
Old Sep 28, 2004 | 02:50 PM
igo4bmx's Avatar
oh my car i couldn't even see it from the outside of the rubber.
I would just make sure to put the vacuum manifold between the brake booster line and the intake manifold
Old Sep 28, 2004 | 02:57 PM
adictionbass's Avatar
Default Re: (igo4bmx)
the check valve is the grey top-hat looking thing on the bracket right above your brake master cylinder
Old Sep 28, 2004 | 03:25 PM
toolowsol's Avatar
Default Re: (adictionbass)
I taped my GE vac mani there, it works great, solved all my issues as far as bov not working properly, boost gauge not rock solid etc.
Old Sep 28, 2004 | 04:03 PM
Bailhatch's Avatar
Default Re: (toolowsol)
On cars that don't have the grey top hat jobby there is a valve that is pressed into the line. It is in the same location and can be seen as a slight bulge. The easiest way to find it is to squeeze the line, it's the hard part. just T in between the bulge and the IM.
Old Sep 28, 2004 | 04:30 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Bailhatch)
yea, on my car its in between the bracket against the firewall.
Old Sep 28, 2004 | 04:32 PM
adseguy's Avatar
Speaking of this GE manifold I got one and I want to get the fittings, but i can't find them anywhere. It seems to be metric fittings. Where should I try looking. I went to Autozone, Lowe's, O'Reily's, muffler shop, the family center. where can I find the 1/2 nipple and the 1/8 nipple
Old Sep 28, 2004 | 07:20 PM
Default Re: (adseguy)
mcmaster.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">On cars that don't have the grey top hat jobby there is a valve that is pressed into the line. It is in the same location and can be seen as a slight bulge. The easiest way to find it is to squeeze the line, it's the hard part. just T in between the bulge and the IM.</TD></TR></TABLE>
ill look on that tom.
Pman92
Sep 19, 2007 04:59 PM
b_serious
Mar 30, 2006 02:36 PM
spark plugs.
Apr 28, 2004 04:58 AM
TypeDC4
Oct 23, 2003 05:13 AM
Integra_Boi
Aug 13, 2002 02:10 AM
