will this intercooler be big enough
Old Sep 29, 2004 | 03:27 PM
slammin86's Avatar
Default will this intercooler be big enough
Will a intercooler with a core size of 2.75 x 6 x 25 be enough for 300 whp on my honda civic?
Old Sep 29, 2004 | 03:41 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: will this intercooler be big enough (slammin86)
Ideally you would want something with more tubes and shorter tubes, like 2.75 x 12 x 12, and make sure the endtanks flow nice and aren't some square clunky homemade POS.
Old Sep 29, 2004 | 05:01 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammin86 &raquo;</TD></TR><TR><TD CLASS="quote">Will a intercooler with a core size of 2.75 x 6 x 25 be enough for 300 whp on my honda civic?</TD></TR></TABLE>
I think you are referring to the JRC (Johhnyracecar.com) IC right?
I have that one too. It's a great deal for the price and for up to 300whp it should be OK. After that you'll probably need a better one. He also sells one that's even bigger for $195. I'd get that one then you may be able to do 325 or more it just depends on the setup. I think one guy made 350whp on the one you were refering to above, but don't expect that. He probably had higher IAT's and could do a lot more HP if he used a bigger IC.
IMO that'll work for your target HP...but no more
Old Sep 29, 2004 | 05:15 PM
slammin86's Avatar
Default Re: will this intercooler be big enough (adseguy)
i am unsure on the brand. i thought it might have been johnny racecar but after lookin at the dimensions of the racecar ones, i dont think it is.
Old Sep 29, 2004 | 05:57 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammin86 &raquo;</TD></TR><TR><TD CLASS="quote">i am unsure on the brand. i thought it might have been johnny racecar but after lookin at the dimensions of the racecar ones, i dont think it is.
The core of this one is that size. The size on this website is the total with end tanks which makes it bigger. Either way like I said it looks OK for 300WHP, but that is definately the limit for it .
Old Sep 30, 2004 | 10:33 PM
hondaboii's Avatar
Hello,
I have a question that might be on the same topic. I saw before that people weld two intercoolers together, meaning that for example I have seen two little ones and just weld the middle part and end cores to make a BIG one...
My question is...is there a downfall with this setup? or is it ok to do that? I heard that its bad because there is no "smooth flow" vs if it were of course one BIG intercooler..
Thanks in advance...
regards,
hb
Something like this...(i got this pic somewhere I forgot)
Old Oct 4, 2004 | 06:21 AM
slammin86's Avatar
Default Re: will this intercooler be big enough (tjbizzo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo &raquo;</TD></TR><TR><TD CLASS="quote">Ideally you would want something with more tubes and shorter tubes, like 2.75 x 12 x 12, and make sure the endtanks flow nice and aren't some square clunky homemade POS. </TD></TR></TABLE>
this one does have square endtanks
Old Oct 4, 2004 | 06:33 AM
White Smoke's Avatar
i my honda
Global Mod
That entirely depends on witch type of core and endtanks that will be used.
A pic would give us more info
Old Oct 4, 2004 | 07:16 AM
Mase's Avatar
Default Re: will this intercooler be big enough (si2die4)
ive seen a johnny race car IC make 400 whp.
so 300 whp is capable.
Sic_DA_Nine
Nov 27, 2007 02:46 AM
OMG WTF
Sep 24, 2006 08:08 AM
SiR99
Jun 14, 2006 05:25 PM
Black DC2
Jan 30, 2005 04:39 AM
LBR92DA-T
Feb 10, 2004 09:44 AM
