Boost troubles/motor is done for
Old Sep 29, 2004 | 07:45 PM
Don Johnson's Avatar
Default Boost troubles/motor is done for
Problem 1: oil blew out somewhere on the driver side of the motor (by the timing cover). Lost about 3 quarts of oil
Problem 2: Compression: 190, 120, 190, 90
The timing belt was off a tooth ever since I got the motor in. It pulled insanely great, pulled in noticed the oil problem. Let the car sit, starts up fine. I go to start it again to put it onto the jacks - takes forever to turn over - thats the point where i get scared and do the compression check.
So my story is, it pulled awesome until I noticed the oil. Still started up fine after oil probem, then all of a sudden it wont start right and the compression is down.
what is most likely the problem, ie. seals, pistons, valves?
Just looking for some help
Old Sep 30, 2004 | 07:36 PM
Default Re: Boost troubles/motor is done for (METAL MULISHA)
Okay, my balance shaft seal blew, hence the oil problem. That will be replaced - but would that explain my bad compression? My timing was off a tooth from TDC ever since I got it if that makes any difference.
TTT for some help
Old Sep 30, 2004 | 08:30 PM
m R g S r's Avatar
Well you could start by telling us what engine? I'm guessing h22 b/c of the balance shaft seal thing.
Old Sep 30, 2004 | 08:45 PM
vaporboy12's Avatar
Default Re: Boost troubles/motor is done for (m R g S r)
im running i tooth retard on the retard side it runs fine compression is good just too lazy to fix it
is it a new motor?
Old Oct 1, 2004 | 01:00 PM
Default Re: Boost troubles/motor is done for (vaporboy12)
yes, its an h22 prelude. the motor is newly boosted, less than 100 miles. When I got the motor, the compression was 190 all the way across
Old Oct 5, 2004 | 10:47 PM
Replaced the belt, fixed the timing problem, got the blanace shaft seal on and still low compression in cylinder #2 and 4.
More tear down will ensue, but does this sound like a valve problem?
edit: compression is now 190-150-190-150. Its better, but still not good. Should I try that gay compression restorer stuff? Hell, it cant hurt
Paluce
Mar 21, 2007 04:30 PM
RedGSR1994
Nov 21, 2006 05:10 PM
v930
Feb 12, 2005 06:17 PM
92TypeR
Sep 1, 2003 12:22 PM
Thirty-Nine
Jun 23, 2003 02:29 PM
