100 shot nitrous possible on b16a??
Old Sep 28, 2004 | 02:05 PM
f1 vtec's Avatar
Default 100 shot nitrous possible on b16a??
hi just wanted to know whether it would b possible to spray 100 shot nitrous on a b16a which has vafc/fuel pump/type r cams+spoon cam gears and full cat removed exhaust system. ive been spraying 75 shot for past couple of months all good so far with timing back 4 deg.
any help appreciated thanks
p.s with zex dry shot
Old Sep 28, 2004 | 02:06 PM
Turbo E's Avatar
with proper tuining 100 should work. direct port tho, not a dry shot.
Old Sep 28, 2004 | 02:07 PM
f1 vtec's Avatar
Default Re: (Turbo E 604)
yea i forgot to mention its a zex dry shot
Old Sep 28, 2004 | 04:32 PM
JSpin's Avatar
Default Re: (f1 vtec)
well, b16's ARE pretty cheap
Old Sep 28, 2004 | 04:37 PM
aut0tek's Avatar
Default Re: (JSpin)
lol 100 shot dry on a b16!?!?
Old Sep 28, 2004 | 04:46 PM
mrbsponge's Avatar
the good thing about a zex kit is it meters the nitrous off of fuel pressure, so if it senser lower fuel pressures you wont recieve a "100" shot, i tried this on a B16 and only netted 82HP from the "100 shot" but i tuned it with uberdata and watched the timing and AFR's
Old Oct 1, 2004 | 12:16 PM
f1 vtec's Avatar
Default Re: (mrbsponge)
if i use a walbro 255lph fuel pump it should aid in getting more fuel in there, also got a vafc tuned so wonder what i can hit??
Old Oct 1, 2004 | 01:39 PM
londa hover's Avatar
definetley not w/ dry shot. you'll be getting around 35% n2o in the 1st chamber! thats like... i dont know around 35hp!! i have 100shot direct port on my b18c1 w/just bolt ons.
Old Oct 1, 2004 | 02:05 PM
K20DC2R's Avatar
Default Re: (londa hover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover &raquo;</TD></TR><TR><TD CLASS="quote">definetley not w/ dry shot. you'll be getting around 35% n2o in the 1st chamber! thats like... i dont know around 35hp!! i have 100shot direct port on my b18c1 w/just bolt ons. </TD></TR></TABLE>
How much hp and what kind of times are you pulling?
Old Oct 1, 2004 | 02:08 PM
Default Re: (VtecWhore)
271whp@8500
220wtq@5300
1/4 13.11@102 1.88 60'
times seem a little off cause im 3750ft above sea.
Old Oct 1, 2004 | 05:39 PM
RyanEJ8's Avatar
Default Re: (aut0tek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aut0tek &raquo;</TD></TR><TR><TD CLASS="quote">lol 100 shot dry on a b16!?!?
Why not? I ran 100 shot dry on my D16. Many others have as well.
Old Oct 1, 2004 | 05:42 PM
RyanEJ8's Avatar
If you mount your nozzle 18" from the throttle body it will distribute perfectly fine.
Old Oct 3, 2004 | 02:03 PM
SiR831's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londa hover &raquo;</TD></TR><TR><TD CLASS="quote">271whp@8500
220wtq@5300
times seem a little off cause im 3750ft above sea.</TD></TR></TABLE>
stock motor? That's some good power for a simpl set up.
Old Oct 3, 2004 | 02:14 PM
Default Re: (SiR831)
yep stock bottom end. my mods are
3" intake w/aem filter
4-1 vibrant header w/ 2 1/2"collector
tenzo type2 exhaust
act stage3 6 puk clutch
act 8.8lb flywheel
unorthodox racing crank pullie
skunk2 im
rce 310cc injectors
walbro255lph fuel pump
skunk2 stage1 cams
supertech valvetrain
100shot dp nx
hondata es200
next season ill have skunk2 stage2 cams and cp 11.5:1cr pistons, crower rods, rs sleeved block w/120shot
Old Oct 3, 2004 | 06:56 PM
JDMs1eeper's Avatar
Default Re: 100 shot nitrous possible on b16a?? (f1 vtec)
I ran my car with a n.o.s. dry kit. only warning i have is, if your clutch is warn at all. it will not wanna hold it.
Full interior, Stock slipping clutch, 13inch steelies with $25 POS tires
13.2 @ 105 babying it, went from idle, started spraying in 3rd.
first and only run i got with the nitrous. was deffinaly a mid 12 easy
Bottle was at 800psi with 100jet dry shot
SAFC tuned , RC440 injectors, i/h/e full interior 2360lbs w/ driver
B20b, GSR tranny, LS ecu.
Never had any problems with it.
Old Oct 3, 2004 | 07:53 PM
aut0tek's Avatar
Default Re: 100 shot nitrous possible on b16a?? (JDM S1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM S1eeper &raquo;</TD></TR><TR><TD CLASS="quote">...
Never had any problems with it.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1 vtec &raquo;</TD></TR><TR><TD CLASS="quote">hi just wanted to know whether it would b possible to spray 100 shot nitrous on a b16a...</TD></TR></TABLE>
Old Oct 3, 2004 | 08:19 PM
SiKid86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM S1eeper &raquo;</TD></TR><TR><TD CLASS="quote">I ran my car with a n.o.s. dry kit. only warning i have is, if your clutch is warn at all. it will not wanna hold it.</TD></TR></TABLE> haha i was running a 65 shot on a zex dry kit.. OMG the clutch was burning so bad.. eheh i traded my kit for a turbo and mani...
Old Oct 4, 2004 | 01:21 PM
JDMs1eeper's Avatar
Default Re: 100 shot nitrous possible on b16a?? (aut0tek)
... </TD></TR></TABLE>
i know he said b16, but just saiy my B series held great. and b20's are the weak link.. as so people like to say anywayslol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKid86 &raquo;</TD></TR><TR><TD CLASS="quote"> haha i was running a 65 shot on a zex dry kit.. OMG the clutch was burning so bad.. eheh i traded my kit for a turbo and mani...</TD></TR></TABLE>
lol same , 6-puk + t61 @ 18psi. I just hope the new clutch will even hold the power im lookin for
SiR Inspired ED7
Jan 13, 2009 09:38 PM
BojeEM2
Honda Civic (2001 - 2005)
14
Sep 12, 2007 02:13 PM
1990 CRX Si
26
Feb 9, 2006 04:56 PM
integranator
Dec 22, 2002 02:58 PM
EFing8
Dec 19, 2002 07:59 PM
