Integra Turbo Heat Problem!!! Is This Normal?
Old Sep 25, 2004 | 09:06 PM
deeweewoo's Avatar
Default Integra Turbo Heat Problem!!! Is This Normal?
I just turboed my 95 Integra LS and it seem that everything under the hood is ten times hotter. Its melting the plastic protectors off my wires in some cases. I do have a water cooled toubo so I know thats a problem. I think most of it is coming off the manifold and not going anywhere so its heating everything up. How do I stop this? Does anyone else have some sort of heat problem? If so what did you do to resolve it?
Old Sep 26, 2004 | 06:58 AM
dornon13's Avatar
Default Re: Integra Turbo Heat Problem!!! Is This Normal? (deeweewoo)
bump so you will start driving your friggin car
Old Sep 26, 2004 | 07:38 AM
SSBPGSR's Avatar
Default Re: Integra Turbo Heat Problem!!! Is This Normal? (dornon13)
you really get money for reading emails? SIGN ME UP!
Old Sep 26, 2004 | 07:41 AM
deeweewoo's Avatar
Damnit chris now you got people off topic!
GEN2TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deeweewoo &raquo;</TD></TR><TR><TD CLASS="quote">I just turboed my 95 Integra LS and it seem that everything under the hood is ten times hotter. Its melting the plastic protectors off my wires in some cases. I do have a water cooled toubo so I know thats a problem. I think most of it is coming off the manifold and not going anywhere so its heating everything up. How do I stop this? Does anyone else have some sort of heat problem? If so what did you do to resolve it?</TD></TR></TABLE>
Depending on the kind of rad you've got, (full size-integra, half size-civic). There are a few things you could do. Run a second fan with the full size rad. Alluminum rads are a better way of keeping things cool also. Water wetter could be used too, to keep the temps down.
Old Sep 26, 2004 | 08:00 AM
Seth21's Avatar
What kind of turbo is it? A smaller turbo will get way hotter than a larger one let me know.
Old Sep 26, 2004 | 09:58 AM
dornon13's Avatar
Default Re: Integra Turbo Heat Problem!!! Is This Normal? (550whp)
sorry jerd i was trying to help you get the integra back on the road...if it helps guys he is using T3/4 sorta small(we dont know the specs) and only on like 5psi it still gives off alot of heat..oh yeah ssauto mani if that makes any diff....
Old Sep 26, 2004 | 10:08 AM
SiRkid's Avatar
that does seem somewhat excessive. running really lean?
i know my manifold heat wrecked my hoods paint. it was fine..turbo the car..and it got "chicken feet " all right over where the manifold sits..thats about it for me though. it didnt melt anything.
Old Sep 26, 2004 | 10:23 AM
dornon13's Avatar
Default Re: Integra Turbo Heat Problem!!! Is This Normal? (SiRkid)
he says the a/f is perfect
Old Sep 26, 2004 | 12:11 PM
LudeyKrus's Avatar
Just use some heat wrap on everything. Also, using a vented hood would help.
Old Sep 26, 2004 | 02:48 PM
Seth21's Avatar
Default Re: (LudeyKrus)
Does he have a EGT you can hook up and look at?
Old Sep 26, 2004 | 03:41 PM
rondigs's Avatar
Default Re: (550whp)
I had the same problem untill:
https://honda-tech.com/zerothread?id=964885
Old Sep 26, 2004 | 08:17 PM
dornon13's Avatar
you guys know of any kind of heat shield material that might be able to go on the hood if so where do you get it
Old Sep 26, 2004 | 08:23 PM
scooter's Avatar
roof flashing from Home Depot works great, and its cheap.
scott
Old Sep 26, 2004 | 11:08 PM
crispydee's Avatar
I just wrapped the manifold and down pipe with exhaust heat wrap. Under hood temps went right down and nothing gets hot now. You can put your hand on the manifold!
Old Sep 27, 2004 | 12:29 PM
deeweewoo's Avatar
Thanks for all the input guys. Ill try some of the ideas and see if it solves my problem. Ive heard that SSautochrome manifolds are not supposed to be wrapped so I am a little skeptical. Has anyone done this? If so let me know how it worked out.
Old Sep 30, 2004 | 04:02 PM
deeweewoo's Avatar
I ended up buying some thermo-tec cool-it insulating sheets ant I am goint to attach it to the under side of my hood. So hopefully it will help.
Old Sep 30, 2004 | 11:35 PM
crispydee's Avatar
That wll stop the hood getting hot but will increase the under hood temp more because the heat carnt get out through it. please correct me if im wrong.
Old Oct 1, 2004 | 09:12 PM
deeweewoo's Avatar
Default Re: Integra Turbo Heat Problem!!! Is This Normal? (crispydee)
You are probably correct I am just doing this to keep the paint on my hood for now I am going to install another fan also to help disipate the heat.
Old Oct 1, 2004 | 10:26 PM
crispydee's Avatar
You can try taking the rubber seals off the under side of the hood. This will let more air pass under the front edge over the engine and out of the back.
Old Oct 2, 2004 | 01:02 PM
deeweewoo's Avatar
I installed a second radiator fan on a switch so i can run it all the time and it seems to be helping alot. Tahnks for the ideas though.
Old Oct 3, 2004 | 12:03 AM
crispydee's Avatar
Ive got no room in mine for that but ive managed to keep the full length radiater which causes a lot of problems with space as i had to mod the exhaust mani because the turbo was about 3" forward of where the radiater sits. Ive got no heat problems but have no room., just fitting my catch can was a problem.
Old Oct 3, 2004 | 12:09 AM
96-EJ6 B18C's Avatar
Heat wrapping your mani and down pipe will reduce ubder hood temps greatly.
Old Oct 3, 2004 | 06:38 AM
dornon13's Avatar
Default Re: Integra Turbo Heat Problem!!! Is This Normal? (96-EJ6 B18C)
the only reason he doesnt wrap the mani is because alot of ppl on here have had problems cracking the ssauto mani especially when they wrap it.
CARflyGUY
Nov 22, 2006 08:10 AM
whitemike1644
Apr 3, 2005 05:00 PM
bluebomb
Jun 17, 2004 08:09 AM
NateTEG95
Aug 16, 2003 10:12 AM
