drivability with 8.1 lbs flywheel?
Old Sep 30, 2004 | 05:52 AM
ash.zero's Avatar
Default drivability with 8.1 lbs flywheel?
the flywheel's made by clutchmasters.
http://www.clutchmasters.com/s...=4867
how would this affect the daily drivability? would i have to double clutch+heel and toe every gear changes?
Old Sep 30, 2004 | 06:31 AM
Muckman's Avatar
Moderator in Chief
Default Re: drivability with 8.1 lbs flywheel? (ash.zero)
LW Flywheels dont affect driveability at all. I have 7.5lb Fidanza and I wish I went lighter.
Old Sep 30, 2004 | 06:35 AM
Finest's Avatar
Default Re: drivability with 8.1 lbs flywheel? (Muckman)
Yea, it'll affect your drivability cuz you'll be flooring it each time cuz it just revs so fast!
Old Sep 30, 2004 | 06:41 AM
ash.zero's Avatar
Default Re: drivability with 8.1 lbs flywheel? (Finest)
like when i downshift, won't bring the rpm down a lot faster?
i mean, i enjoy heel and toe, double clutching...but not sure if i'd like it if i had to do it everytime i downshift...
Old Sep 30, 2004 | 07:11 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ash.zero &raquo;</TD></TR><TR><TD CLASS="quote">like when i downshift, won't bring the rpm down a lot faster?
i mean, i enjoy heel and toe, double clutching...but not sure if i'd like it if i had to do it everytime i downshift... </TD></TR></TABLE>
It does drop pretty quick with the clutch in, but that's what syncro's are made for!
Old Sep 30, 2004 | 08:03 AM
tz-devil77's Avatar
I have a toda 9 lb i htink. The only time i have a problem is starting on a hill(like a drive thru) and have to tach it up to move the damn car so i dont roll back.
But all the rest of the time NO PROBLEMS!!!!!!!!
Old Sep 30, 2004 | 09:54 AM
hatchback_al's Avatar
Default Re: drivability with 8.1 lbs flywheel? (tz-devil77)
just rev match your downshifts, i dont have a light flywheel and i do anyways. it makes the ride much smoother once you can do it right
Old Sep 30, 2004 | 11:24 AM
J337_UNIT's Avatar
Default Re: drivability with 8.1 lbs flywheel? (hatchback_al)
&lt;-- using a 7.5 lb fidanza.. drivabitlity= excellent.. i love rev-matching
Old Sep 30, 2004 | 12:10 PM
Nobody Special's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al &raquo;</TD></TR><TR><TD CLASS="quote">just rev match your downshifts, i dont have a light flywheel and i do anyways. it makes the ride much smoother once you can do it right </TD></TR></TABLE>
^^exactly. Not to mention saves your clutch and saves you from resurfacing that flywheel tens of thousands of miles sooner and buts you life on your synchros indefinitely. The amount of revving you probably do, should have no excuse for not rev-matching.
BTW, driving with a light flywheels is different - but drivability is pretty much the same. Holeshots with slicks is gonna be interesting though..
Old Sep 30, 2004 | 12:45 PM
Archidictus's Avatar
Unceasing Measure
My buddy has a built NA B18C with a JUN flywheel. I'm not sure how much it weighs, but it's light enough that going from hard throttle to neutral sometimes causes the car to shut off . It revs so freely though...it's definately a mod I want to do in the near future.
Old Sep 30, 2004 | 01:01 PM
f22b2tdave's Avatar
Default Re: (Archidictus)
i have zero problems with my findanza, you just have to not be afraid to lay into the throttle a little more. then you're fine. ill see how she likes boost once i get ahold of cft.
Old Sep 30, 2004 | 02:24 PM
jDMJeRk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">LW Flywheels dont affect driveability at all. I have 7.5lb Fidanza and I wish I went lighter.</TD></TR></TABLE>
who makes a lighter one?!
lighten fw are great; youll love the difference. (i have a act prolite 8.8lb)
(i made a thread similar to your post; it has AWESOME info in it; searcg for my user name it was one of my first posts)
Old Sep 30, 2004 | 02:36 PM
hadboosttroy's Avatar
Default Re: drivability with 8.1 lbs flywheel? (jDMJeRk)
[QUOTE=jDMJeRk]
QUOTE]
comptech
Old Sep 30, 2004 | 02:44 PM
jDMJeRk's Avatar
Default Re: drivability with 8.1 lbs flywheel? (hadboosttroy)
whats the weight?
Old Sep 30, 2004 | 02:48 PM
6.75 lbs
Old Sep 30, 2004 | 04:28 PM
drvfast's Avatar
Not bad at all
Old Sep 30, 2004 | 04:42 PM
second edition's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy &raquo;</TD></TR><TR><TD CLASS="quote">6.75 lbs</TD></TR></TABLE>
thats too light in my opinion
Old Sep 30, 2004 | 07:04 PM
Default Re: drivability with 8.1 lbs flywheel? (second edition)
please give a legitimate reason then as to why you think it is too light. not some bs about stalling or no power going up hills, because that is the bs reasons most people give.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by second edition &raquo;</TD></TR><TR><TD CLASS="quote">
thats too light in my opinion</TD></TR></TABLE>
Old Oct 1, 2004 | 08:02 AM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">My buddy has a built NA B18C with a JUN flywheel. I'm not sure how much it weighs, but it's light enough that going from hard throttle to neutral sometimes causes the car to shut off . It revs so freely though...it's definately a mod I want to do in the near future.</TD></TR></TABLE>
I have a built B18C too and my Fidanza flywheel is lighter than the JUN FW. I have no stalling problems like that. I think problems like that can be linked to an old IAC valve or something wrong with the idle system. Unfortunately I think the flywheel gets blamed all too often.
Old Oct 1, 2004 | 08:51 AM
djwest24's Avatar
Default Re: (Muckman)
using the fidanza 7.5 lbs. it helps build boost really quick.
Old Oct 8, 2004 | 05:27 AM
BigC-ivic's Avatar
are these flywheels good for NA aplications
I want to get one when I do my clutch next spring. I beleive the ITR flywheel is 14lbs. but maybe I should go closer to 10? I don't want to go all out, but I'd ove a more responsive car.
JdmGizmo
Feb 16, 2008 04:55 AM
Boostage
Jul 5, 2007 03:01 PM
vtec4max
Mar 8, 2007 03:39 PM
mattdenali
Sep 13, 2005 04:19 PM
zseeanz
26
Jan 16, 2004 12:10 AM
