Clutch need help
Old Sep 28, 2004 | 09:58 AM
Corinthians's Avatar
Default Clutch need help
I have an exedy single plat metalic clutch ,it took about less than 6 month and it is gone case,what do i need to do ,do i need to purchase the whole kit again or can i just replace certain parts .Since the plate is 3 puck can i replace with some other disc that last longer if i am not mistake is the disc only need to be replace right?
Old Sep 28, 2004 | 11:46 AM
green_GSR's Avatar
Default Re: Clutch need help (Corinthians)
First inspect your clutch.
Second, check to see if you can find replacement parts without buying the whole kit.
Inspect your pressure plate. If your pressure plate looks fine (no bent or broken "fingers"), then you can keep your existing pressure plate. Then inspect your flywheel. If your flywheel is overheated and gouged out beyond repair/resurfacing, then you have to replace your flywheel. If your flywheel looks fine, then resurface your flywheel and you're good to go. Replace your clutch disc.
ek-g6
16
Feb 15, 2008 11:25 PM
94DB8
Feb 1, 2008 07:55 AM
h8ted ek
Dec 22, 2006 07:41 PM
methanemotorworks
Feb 13, 2006 07:32 PM
DPSJosh
Aug 26, 2005 06:09 AM
