hondata 4bar
Old Feb 20, 2012 | 01:04 PM
bigtom388's Avatar
Default hondata 4bar
ok i got a bad map sensor but the place i bought it from wont return calls and i got nothing back from hondata either does anyone know what else i can do need to get my car running right a got a mustang guy talking all kinds of s**t lol need to shut him up
Old Feb 20, 2012 | 01:12 PM
sp00led's Avatar
Default Re: hondata 4bar
Have you tested it with a volt meter? What makes you think the map sensor is bad?
In my experience you can't change map sensors and just pick a new setting in hondata and it run nominally. You generally end up having to retouch the tune. That being said you could always run a stock sensor if you keep boost to 10psi or less.
Old Feb 20, 2012 | 01:15 PM
92frostwhtdb2's Avatar
Buy another map sensor, you got basically got f**kd.if the manufacturer won't respond ,nobodys going to give you a free map sensor
Old Feb 20, 2012 | 01:58 PM
bigtom388's Avatar
yea i tested it, with engine running it reading 14.5 mv which is.01volts and it supposed to be.30volts and with the key on engine off its only like 35mv which is less than 1 volt and its supposed to be 1.1 volts
Old Feb 20, 2012 | 05:38 PM
hon2984's Avatar
what ECU are you running? I had problems with mine when I installed it, the engine wouldn't stay running. Put a stock map back on and it ran like before. I needed to change the settings in S300. It has been installed on the car for 2 months now no problems!
Dave_yd
Mar 24, 2008 12:57 PM
EJ8 GSR-T
Apr 17, 2007 09:09 AM
b16 matt
Sep 21, 2004 07:00 AM
oemDC2
Jan 5, 2004 09:45 AM
