q16 or e85
Old Mar 2, 2012 | 06:51 PM
boostd ls's Avatar
Default q16 or e85
just wondering what the power difference is and some pros and cons of each if anyone has had experience with both its going in a boosted k making around 700hp
Old Mar 4, 2012 | 11:04 PM
1fastk's Avatar
Default Re: q16 or e85
Never used q16 but e85 will easily get you 700 wheel, not to mention its cheaper
Old Mar 5, 2012 | 01:50 PM
boostd ls's Avatar
its kinda hard for me to get e85 i have to drive to a naval base and get someone to get me on the base to pump it so i have been looking into q16 i can order it from a local shop in my town just wanting toknow if its better
Old Mar 6, 2012 | 03:45 AM
darkhorizon's Avatar
The local shop should be able to get E98, which would be about 1/5 the cost of Q16 with similar results.
Q16 is pretty nice, just make sure the injectors you have are compatable. I have ran c16 in my race cars... I like the results as the fuel has some different characteristics than E85, but it is hard to say which is better.
Old Mar 6, 2012 | 09:23 AM
kbouchard1092's Avatar
E85 is much cheaper, although requires a more expensive fuel system for the additional gas that will be needed Vs. Pump gas to make the same power. Rule of thumb 30% more.
It can get expensive quick when u look at the price of ID's 2000cc, plus the need of a big fuel pump, and depending on power goals bigger fuel lines. If you have e85 in the area it might be better for u if youre budget permits..
Some like just getting race gas here and there for the track, and see that being a better cost effective solution
Old Mar 6, 2012 | 02:36 PM
boostd ls's Avatar
my local guy only sells vp stuff i aksed about e85 today and he said he dont think he can get it my fuel system should b fine got aermotive pro pump and 1600cc injectors sumped tank and aermotive reg
Old Mar 6, 2012 | 02:37 PM
boostd ls's Avatar
anyone know the price difference between q16 and c16
SPOOLINmatt
Jan 22, 2012 09:32 AM
reddcoupe
Sep 15, 2010 06:50 PM
insaneconceptz
Mar 8, 2010 12:53 PM
Boostage
Jul 3, 2009 03:21 PM
93LSivic
May 26, 2003 10:16 PM
