cam seal stuck in pvc black box opening instead of block off plug, need HELP!!
I got the wrong plug for my black box and it was a cam seal instead of a block off plug even though the ebay seller said it was a block off plug. Long story short the cam seal got stuck and I am wondering if the seal will just get pressurized and pop out when started or stay their forever ! Also the seal is not magnetic already tried that!
R.I.P. Mark
Re: cam seal stuck in pvc black box opening instead of block off plug, need HELP!!
if you cant get hold of it you will have to drop the oilpan to poke it out from inside
or you could try to pressureise with an air line the motor through the vac port on the valve cover to push it out if it just sitting in the hole
1 Post
if it is "wedged" in there, you can use a gear puller to get it out. if it fell in, just drop the pan. either way not too hard.
ok thanks for all the replies I am going to try air gun blower first and then drop the oil pan if that doesn't work too.
This is the most retarded thing I have seen posted in a long while on this site. I order many things from Ebay, and if the wrong part shows up, then call the seller, they will more than likely get you the right part. If not, report it to Paypal/Credit card company. You will have your money back right away. As for getting it out, if it will take some pressure, try to drill a hole and pull it with a hanger, or drop the pan and pop it out with a finger.
If its rubber run a drywall screw in it and pull it out with pliers.
egcoupe[lsB16]
11-23-2010 07:45 PM
H4CRXSi
02-22-2010 03:53 PM
2K_TEG
11-05-2002 10:06 AM
