Headwork opinions
Old Feb 27, 2012 | 03:51 PM
Slacker93eg's Avatar
10 Year Member
Default Headwork opinions
I'm running a p72 GSR head for my lsvtec (turbo later - see build in sig), but I want to know, should I do any head work to the head before I put this together N/A? I was thinking about replacing the guides and keepers just to be safe, and lapping the valves. Should I get a valve job or anything done? Obviously getting the work done would only benefit, but would it be necessary?
Old Feb 27, 2012 | 04:12 PM
DirtyDA9's Avatar
Default Re: Headwork opinions
Lapping should be sufficiant, valve jobs are only needed when the seats aren't sealing. You can lap it yourself, I'm sure you know that, but I would have the machine shop replace the guides.
Old Feb 27, 2012 | 04:20 PM
10 Year Member
You think I should replace the guides and keepers then?
Old Feb 27, 2012 | 05:26 PM
DirtyDA9's Avatar
Yes, it would be worth it while the head is apart, instead of having to do it down the road. Or just have them measure the valve stem and guide bore to see if you need replacing in the first place. But it's good to anyway.
Old Feb 27, 2012 | 05:31 PM
10 Year Member
Sounds like a plan, when I go turbo later down the road I'll upgrade the springs and replace the valves. Thanks!
Old Feb 27, 2012 | 07:35 PM
DirtyDA9's Avatar
Yessir When you do upgrade the springs and valves, just to be sure, measure the guides to make sure the guide to valve clearance is still in spec. Good luck with everything!
Old Feb 27, 2012 | 07:45 PM
vwbased's Avatar
have a nice day
Old Feb 27, 2012 | 07:59 PM
DirtyDA9's Avatar
Originally Posted by vwbased
You need to grind the seats if you replace the guides. The seats will no longer be concentric with respect to the guides and therefore the valves will leak. Lapping will not correct this situation.
If the machine shop does the guide install right, there shoulding be a problem.
dantamparacer
Aug 1, 2011 09:34 PM
jyacoba2009
10
Oct 13, 2009 10:21 PM
Xscort
May 21, 2009 08:09 PM
95dc2teg
Jan 27, 2008 05:20 PM
Trajic
Jul 4, 2001 01:13 PM
