Turboing B18B1 with Turbonetics T72 turbo
This turbo is large, and heavy as ****. I'm gonna guess its 20lbs.
I'm worried about how heavy it is (I bought an ebay iron cast manifold)
Ive read around where people would use brackets to support the turbo's weight, double manifold gaskets, bigger bolts I think...
I need more opinions. I would even consider relocating the turbo elsewhere in the car. I want to mount it somewhere where I won't worry about it. I would be down to use brackets to support the weight, but I need more opinions before I go any further, I'll return the manifold or buy another if needed.
If anyone is selling a top mount turbo manifold, I will buy!
Thanks
Thanks
Re: Turboing B18B1 with Turbonetics T72 turbo
I'm gonna stick with it, I think it will do fine. It has a .58 exhaust side, the smallest turbonetics offers. Once its one and if I don't like it, I'll trade it for something smaller. I plan on only running 8 -10lbs
Lol, I see you need to do some more reading here: https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Good luck!
Good luck!
Massive turbo for a low revving engine. you should have about 1000rpm of powerband if your lucky, wow that will be a fun car for sure !
Honestly, an old style 72mm turbo like the Tnetics should be good for 750, maybe 800whp on a Honda. Even with the .58 A/R housing you're looking at starting to build boost at 5000+ RPM's, which would drive like ***** on a low-rev B18B.
Sell it, and get something more appropriate. Period. You'd drop out of boost after every shift and your car really wouldn't be a whole lot faster.
**** this is not what I wanna hear.
would turbo cams make it worth my while, hence allowing me to rev higher, what are my options? stock head and block for now. cams, springs, retainers, where to buy, and what?
i have a turbo off a old school bus. it might spool earlier if not you could use the brackets to support the weight
Moderator
Having said that.. I'll say this.. GET ANOTHER TURBO TO USE AND STOP WASTING MONEY AND TIME ON THE LS HEAD. GET REALISTIC GOALS WITH REALISTIC PARTS..
You're more than likely going to get any other suggestions about the other parts, because you're starting off BAD from the beginning by using this turbocharger and think that other parts are going to help remedy your first BAD choice from the beginning... it won't work, sadly.
The ONLY way this turbo will work out for you is if:
-You build a head, preferably a vtec head, ported to the gills, full valve train etc.
-build the block ( the stock rods and pistons wont handle high rpm's)
-Rev the **** out of it to like 10,000+ rpm
You will be making 500+ whp, so plan to spend money accordingly to build to suite, many many thousands.
It's just not the right turbo man, get something smaller
Why is it out of the question to sell it? im sure someone here can use it, believe me, you will be much more happy. Ive been down this road before..... my car was actually slower than a stock b16a hatch...... do yourself a favor and sell it.... The LS motor is a great platform to boost, but I wouldnt put anything larger than a 60mm on it.
