oil drain line
Old Mar 13, 2012 | 01:07 PM
piggy96's Avatar
Default oil drain line
so i just had my turbo rebuilt. When i picked it up he said my oil drain line was too small. I currently have 1/2 npt fittings at both ends and a -10 stainless line. What he told me that for my turbo (custom built garrett t3/t4) the drain should have a minimum of .600" diameter. Does this makes sense or should i be ok. I dont want to have to rebuild my turbo again lol
Old Mar 13, 2012 | 01:32 PM
nealnanoHX's Avatar
Default Re: oil drain line
-10 AN lines for a drain is pretty standard for a t3t4 turbo.
Old Mar 13, 2012 | 03:37 PM
Whiterice-gsr's Avatar
^^^agreed i like a -12 but 10 should be fine thats what 90 percent of ppl have
Old Mar 13, 2012 | 10:14 PM
piggy96's Avatar
thanks for the help. i think what he was talking about was the fittings so maybe ill just change that up just to be on the safe side
Old Mar 14, 2012 | 04:19 AM
xXSanderXx's Avatar
Mine is 10AN.
Old Mar 14, 2012 | 06:22 AM
Bix VT's Avatar
Did you have to rebuild the turbo because of lack of drainage, or another reason? How was the angle on the drain? Where was your return tapped into the oil pan? Was the line kinked at all?
-10 should be sufficient, I'm thinking your problem was something other than the size of the line.
Old Mar 14, 2012 | 06:40 AM
nealnanoHX's Avatar
^^ Agreed
Old Mar 14, 2012 | 12:37 PM
with drainage, gravity must be allowed to do its job or it will back up and cause issue.
Old Mar 14, 2012 | 02:34 PM
racebum's Avatar
hang on, who didn't catch that 1/2" npt is the same as 8an?
Old Mar 14, 2012 | 04:43 PM
right so hes choked on both ends but proper in the middle.
Old Mar 14, 2012 | 04:49 PM
Dc4LsTeG's Avatar
EK9
No one except you apparently
Get 10an fittings
Old Mar 14, 2012 | 11:55 PM
piggy96's Avatar
lol. this is why i am changing the fittings, its a topmount setup, angle is great for drain and the fitting on the pan is as high as possible. no kinks
once again thanks for the help everyone, kind of hard to find the smaller details like this
cfwthb_94
Mar 19, 2010 12:22 PM
BigZeke5
Oct 16, 2008 06:20 AM
projectxspeed
Apr 19, 2005 03:45 AM
94lsboost
Nov 28, 2004 03:33 PM
DOHCarp
Mar 8, 2002 09:36 AM
