Boostie 2012
Old Feb 15, 2012 | 05:37 PM
Natural Aspirations's Avatar
Default Boostie 2012
New project for the year is coming together and have a few final pieces to decide on to finalize the build. I have no goals other than to have a well matched fun car. I have everything narrowed down except the cams and intake manifold, I haven't seen anyone make a decent attempt at making the BC3+ cams work. The 5858 is a 60+lb/min turbo and is on the edge of being able to take advantage of a "larger" cam. The BC3+ is a smaller version of the Pro1 which is one of the current big turbo cams of choice.
Stock Sleeve GSR
Mahle pistons ~10.5:1
Manley Rods
GSR head CC Ported
+1mm Intake Valves
Supertech Springs, Guides and Retainers
BDL cam Geaars
(Cams?) GSR/ITR/BC3+ (have all 3)
(Intake Manifold) Have Blox...... buy Victor?
Synapse Ramhorn
46mm Precision Wastegate
3" DP
Precision 5858SP-BB
Full Race 22x8x3 Backdoor IC
2.5" charge piping
Tial 50mm BOV
93 Octane
ID 725cc Injectors
DW301 Pump
AEM Methanol Injection
Fuel Lab FPR
Old Feb 15, 2012 | 05:42 PM
Default Re: Boostie 2012
Ive gone
D15--->DOHC ZC--->B20--->Cookie--->B20 Revisited--->B20 Supercharged--->GSR Supercharged--->Boostie
Are those Natural Aspirations?
Old Feb 15, 2012 | 05:49 PM
93typerhatch's Avatar
Great set up.. i would go with the victor and itr cams but that depends on Ur power goals... With Ur compression its gonna make great power and I see Ur gonna use meth..
Old Feb 16, 2012 | 04:41 AM
D-Rob's Avatar
You'll be fine with the manifold you have now.
Old Feb 16, 2012 | 07:26 AM
mar778c's Avatar
Community Builder
Community Influencer
Like D-Rob said, the mani is good.
I would go with ID1000s instead of ID750s. This is a 500+ whp capable engine, the 750 will run out very quickly.
Old Feb 16, 2012 | 11:24 AM
D-Rob's Avatar
They will be alright if he uses the meth. Methanol injection is a secondary fuel, taking some load off the injectors.
Old Feb 16, 2012 | 12:01 PM
DirtyDA9's Avatar
Can't wait to see the finished product
Old Feb 16, 2012 | 03:26 PM
DDTECH's Avatar
Good setup, Choose the profile that best utilizes what you are trying to do. Being a turbo car, i suggest running a hybrid cam setup.. medium sized intake with a good sized exhaust.
Old Feb 20, 2012 | 05:49 AM
ID1000's ordered just to be safe along with a 4Bar. Will likely be running the S2s1's after talking with Derrek (D-Rob) it seems like the logical choice for my goals. Morgan said the manifold will be shipping this week. Oil lines came from Go-Auto last week, I think all I have left to purchase is an exhaust.
Any advise on exhausts? VRS seems to be the best priced piping kit, but by the time I have all the parts for the system bought and welded together I could have bought a complete cat-back such as the skunk2 76mm megapower RR. The $120 eBay 3" is a bit tempting as well, I have a buddie who has one and has not had any issues.
Old Feb 22, 2012 | 07:15 AM
bierelion's Avatar
UP
Old Feb 23, 2012 | 02:12 AM
Almost...... I ended up with the incorrect DP so it will be another week until its running.
Talking with Rocket about a set of M21's will likely be going with a set of those which is a CTR+ profile for the most part.
Old Feb 23, 2012 | 01:39 PM
Omni 4Bar
ID1000
Old Feb 23, 2012 | 01:52 PM
Precision 5858 - Ball bearing
Precision 46mm Gate
Synapse Ram/Dump/Down Pipe
Old Feb 23, 2012 | 01:55 PM
Tial 50mm
Full-Race Backdoor Intercooler 22x8x3
2.5" Charge Pipe
DW 300 fuel pump
Old Feb 24, 2012 | 08:07 AM
shawty22's Avatar
I personally have ITR cams, and i love them. I dont know about the BC3+ cams though. But id suggest ITR. They have been proven to make 800+ whp.
Old Feb 24, 2012 | 01:05 PM
DirtyDA9's Avatar
You don't need to "suggest" anything to NA, if anyone knows what they are doing, it's him.
Old Feb 24, 2012 | 01:13 PM
prsxr88's Avatar
nice parts. in for more
Old Feb 24, 2012 | 01:46 PM
Not true, I'm always open for suggestions.
Camshaft choices always haunt me because there are always more choices than information out there. One of the few cams that have been done back to back are the ITR and Pro1, which happen to be the 2 most popular choices. On the famous test ~60whp was picked up by switching to a Pro1 cam with a 35 lb/min turbo, while my turbo is a little bit smaller than that there has to be a compromise between the two choices with all of the options out there.
While I'm not looking to break any records I am looking to produce the most efficient combination I can.
Old Feb 25, 2012 | 04:57 PM
TheShodan's Avatar
Moderator
Camshaft choices always haunt me because there are always more choices than information out there. One of the few cams that have been done back to back are the ITR and Pro1, which happen to be the 2 most popular choices. On the famous test ~60whp was picked up by switching to a Pro1 cam with a 35R turbo, while my turbo is a little bit smaller than that there has to be a compromise between the two choices with all of the options out there.
Fixed. Your turbo is much capable of 58-60lbs/min.
Old Feb 25, 2012 | 05:16 PM
Yea..... I'm not sure how I made that mistake.
Old Feb 26, 2012 | 12:26 PM
Full-Race IC piping fits like ****....
I'd rather not cut the bumper.
May order new, any advise?
Old Feb 26, 2012 | 12:33 PM
Whiterice-gsr's Avatar
cut the piping to make it fit without bumper modification. looks like if u cut 4 inches off the end going to the intercooler it will be about where u want it, hard to tell from that angle.
Old Feb 26, 2012 | 12:44 PM
I cut ~3" off the end that comes out of the IC to get the proper got with the turbo connected to the inlet. The length after the first bend I a bit too long an rather than have 2 bends it has 1 90 degree bend and it just sticks out too far.
Old Feb 26, 2012 | 12:53 PM
u have no other bends left over that work. the kit i got also fit like **** i ended up having to use my old n/a cold air pipe to make it work cuz i used up all the bends, thats why i have it going from 2.5 to 3 inch. i u look at the motor shot in my garage you'll see what i mean. would full race take the kit back if u already cut it?
Old Mar 4, 2012 | 04:34 AM
Well after a bunch of cutting I got things to fit, interesting how custom parts require "adjustment"
Still looking into cams...... I will likely leave the GSR cams in the engine until I can make a decision. Im waiting for some more information about the GSC cams, but it's nowhere to be found just yet.
