Help identify turbo
Old Mar 5, 2012 | 07:44 PM
protopro88's Avatar
Default Help identify turbo (pictures work now)
]I have a turbo tht i was told its a turbonetics 60-1 trim but it has no identifiction on the actual turbo. The exhaust housing is stamped a/f .63 , 5 bolt downpipe. Nothing is stamped on compresser housing. The only other markings are the AF and Mg stamped on the plate that divides both wheels (stamping is on exhaust wheel side. Is this enough information to figure out what company and size? Thanks
Compressor:
Inducer 50mm
Exducer 76mm
Turbine:
Inducer 56mm
Exducer 65mm
Old Mar 5, 2012 | 07:52 PM
DirtyDA9's Avatar
Default Re: Help identify turbo
Where's the picture?
Old Mar 5, 2012 | 07:59 PM
protopro88's Avatar
Pictures wouldnt work so i tried to explain it. Ill work on pictures
Old Mar 6, 2012 | 05:51 PM
protopro88's Avatar
Would it help if i measured the turbine and compressor?
Old Mar 6, 2012 | 06:22 PM
TheShodan's Avatar
Moderator
yes. compressor and exhaust wheels in millimeters please
60-1 is not a "trim". "trim" is a coefficient of the wheel size
Old Mar 6, 2012 | 07:35 PM
protopro88's Avatar
I will have to measure tomorrow with a dial caliper and will put up the info sometime tomorrow. Thanks for that side not, im trying to learn about all these different turbos and its alot to comprehend ha.
Old Mar 7, 2012 | 08:51 AM
protopro88's Avatar
Measurements updated
Old Mar 7, 2012 | 09:49 AM
TheShodan's Avatar
Moderator
Looks old. Looks like a 40 or 46 trim T04E if your compressor wheel measurements are correct (shame you can't see the serial number on the back of the actual wheel).
Those were good only to about 350whp. (especially since you have the stage 3 exhaust wheel). Those were made as a twin setup for larger displacement 4.0 Litres and up. But as a single unit they were pretty good with Straight LS motors up to about 300whp, then they ran out of breath.
Old Mar 7, 2012 | 02:04 PM
protopro88's Avatar
Thanks alot for your help! Is there anyway i can find out forsure if its a 40 or 46 trim?
JaGuAr81
Dec 12, 2012 03:12 PM
notsolfast
Nov 18, 2011 12:23 AM
Coutts
Jul 18, 2010 06:23 PM
GsrIntegra789
Apr 18, 2008 05:45 PM
