intercooler setuo question
Old Feb 15, 2012 | 10:42 AM
Crazy_SI_T's Avatar
Default intercooler setuo question
So i just picked up my new turbo. Precision t67 and the inlet the oiping connects to is 3". My current setup is 2.5. Now my goal is 500whp, now my question is would There be a performance difference if i just put a reducer coupler on? Ratger than re doing the entire setup? Whats your input in this?
Old Feb 15, 2012 | 10:47 AM
TheShodan's Avatar
Moderator
Default Re: intercooler setuo question
For the T67, the Compressor housing to the outlet should be either 2" (E cover) or 2.5" (S) cover. If you got the H cover you're more than likely 3". Otherwise, I'm thinking you're more or less the 2.5" flared that goes to the IC from the turbo.
Either way, using a reducer coupler to fit will not affect performance in a negative way.
Old Feb 15, 2012 | 11:26 AM
Crazy_SI_T's Avatar
here is the turbo
Old Feb 15, 2012 | 01:01 PM
TheShodan's Avatar
Moderator
Originally Posted by Crazy_SI_T
here is the turbo
Measure the Outer diameter of the compressor cover outlet please. (Part that uses a hose coupler to the intercooler) That looks like an H-cover.
Old Feb 15, 2012 | 01:25 PM
DirtyDA9's Avatar
^^ yea I would say it's an H cover.
Old Feb 15, 2012 | 03:06 PM
racebum's Avatar
agree, that appears to be too big for an E cover outlet
Old Feb 15, 2012 | 11:11 PM
Crazy_SI_T's Avatar
measures 3in
Old Feb 16, 2012 | 08:20 AM
TheShodan's Avatar
Moderator
That's definitely an H-Cover, so if you have 2.5" piping, go ahead and use a reducer coupler. You don't have a choice unless you want to change backplates and covers. that's expensive, so go right ahead.
Old Feb 16, 2012 | 02:37 PM
Crazy_SI_T's Avatar
But will thia effect spool time or anything performance related?
Old Feb 17, 2012 | 03:29 PM
Crazy_SI_T's Avatar
bump
Old Feb 20, 2012 | 07:51 AM
EGRhatch's Avatar
https://honda-tech.com/forums/forced-induction-16/intercooler-piping-size-3024864/
93supercoupe
Feb 2, 2012 08:00 PM
spoolinvtec54
Jul 5, 2011 05:31 PM
bigsnorlax
Jun 20, 2011 04:19 PM
acrocat
Mar 25, 2009 12:50 PM
RoachForLife
Jan 25, 2004 11:09 AM
