Stock b20vtec turbo results
Just thought I'd sHare my setup. This is mainly for those who are on a budget(like myself)
Complete breakdown of my setup
1998 Acura Integra GSR 2dr
Motor:
B20Z block
Arp rod bolts
Refreshed block(new rings, hone, bearings)
Napa Headgasket
Stock gsr p72 head
Gsr cams
Supertech valvetrain
Stock GSR IM with butterflies disabled
Stock GSR throttle body
stock gsr trans
Exedy Organic clutch
Stock gsr flywheel
Turbo setup:
Stainless steel quick 4
eBay 57 trim
3 inch open downpipe
Precision 1,200cc
2.25 intercooler piping
eBay intercooler
Suspension:
Kyb gr2s
Stock cut shocks front, eBay coils rear
Energy suspension mount inserts(torque and rear only)
Eyeballed alignment
This setup previously made 296whp 215 torque @8psi of boost, but did a base run before hitting the 1/4 and was only making 265whp 200torque(same dynojet) tuned on cromepro
Drove 3hours to Sacramento, slapped on 22x8x13 slicks mounted on lenso's and did 3 runs
1st run (tires at 12psi, launched at 6,000ish no antilag, bogged on the line and missed 3rd)
2.185
5.826
8.833
13.406@107
2nd run (launched higher 7,000 tires still at 12psi)
1.957
5.468
10.782
12.820@109mph
Last run (finally got my hands on a tire pressure gauge and realized my tire pressure was at 12psi! Dropped them to 10psi driver and 9psi passenger, launched at 7,300)
1.779
5.219
8.075
10.517
12.561@10mph
All runs preloaded(makes a huge difference)
Not the quickest car on here, but I hope this helps SOMEONE who is curious what their setup can run!
Motor:
B20Z block
Arp rod bolts
Napa Headgasket
Stock gsr p72 head
Gsr cams
stock gsr trans
Stock gsr flywheel
Turbo setup:
eBay 57 trim
Precision 1,200cc
eBay intercooler
Suspension:
Kyb gr2s
Eyeballed alignment
2.185
5.826
8.833
13.406@107
1.957
5.468
10.782
12.820@109mph
1.779
5.219
8.075
10.517
12.561@10mph
Re: Stock b20vtec turbo results
although b20 sleeves design suck...
he's only at 300whp, i wouldn't push those stock b20 sleeves past 350-360whp E85....385whp that's where my buddies b20 sleeve cracked.
Budget build.
89 crx, b20z block, stock b16 head, stock pistons, stock rods, stock rod bolts. Victor X intake Mani, BDL 70mm TB. Top mount, Super 70 China copy turbo, 400whp at 10psi boost. 91 octane pump gas.
