turbo kit HP?
Old Feb 22, 2012 | 12:10 PM
queens770's Avatar
Default turbo kit HP?
I'm looking at a few options for my b16a3. Motor is built and ready, looking into a go autoworks turbo kit. When they state on their site that the turbo can produce upto x-amount of HP, are they talking about total with the engine HP or just the kit itself? They have a street kit for 2k looks decent and says kit is capable of 200-300HP?
I hope I'm wrong but if it means total HP with the engine, then $2k for a turbo kit that only puts out 40-160HP and the 160 would be at absolute full boost?? If so I'll guess I'll just go with one of the other kits that will leave a little room for play.
Old Feb 22, 2012 | 12:21 PM
4cylfiend's Avatar
Default Re: turbo kit HP?
The limiting factor is the turbo. You can upgrade the turbo to a larger size wheel that will flow more air. Not one kit can be realistically labeled as a "40-160whp" kit because engine builds can vary from one persons build to the next and can be skewed by things such as compression/cams/headwork/tuning etc. The main thing that is going to significantly increase the power that the "kit" will make is the size of the turbo. The Go-Autoworks kits are really nice kits at a very affordable price. I pieced my first turbo kit together using Greg's components. You can buy the kit and upgrade the turbo and will be perfectly fine.
Old Feb 22, 2012 | 12:28 PM
queens770's Avatar
Ok, that makes a little more sense to me. I'm just looking for 300ish HP, but I've heard boost is a lot like car audio, you always want more once you catch the bug.
This car will be a weekend warrior car, street mostly and the track once or twice a month for LEGAL fun.
Old Feb 22, 2012 | 12:59 PM
4cylfiend's Avatar
Lol well I would recommend going with this kit: http://www.go-autoworks-store.com/gorakit.html
Old Feb 22, 2012 | 01:02 PM
Whiterice-gsr's Avatar
your numbers are off a bit too when they say 300 they mean 300 at the wheels not at the crank, essentially that kit will more than double your actual hp.
Old Feb 22, 2012 | 01:08 PM
queens770's Avatar
Really, well that would be fine then, like I said only looking for 300ish. Hhmmmm
Old Feb 22, 2012 | 01:37 PM
th3pwn3r's Avatar
Making more power requires more money so keep that in mind.
Old Feb 22, 2012 | 01:43 PM
im a bone stock gsr with a 57 trim at 10 psi with dsm 450cc injectors tuned on neptune. 300 is fine for a stock bottom end, anything more is playing with fire.
queens770's Avatar
Money isn't really an issue, I have a $1000 a month I can put into this if I want, then it just becomes a matter of me saving one month to the next lol
Old Feb 22, 2012 | 01:46 PM
queens770's Avatar
That's cool, but the bottom end has already been built, it's done, been done, just looking into turbo kits because I really don't know enought about turbos to build my own kit, figured I'd just buy a kit and upgrade from there if I want to
Old Feb 22, 2012 | 01:57 PM
if u give us a build list we can better help u with a setup that will match your motor
Old Feb 22, 2012 | 02:17 PM
queens770's Avatar
Ok, what I know 100%
Skunk2 pro series intake manifold
Rc 310 injectors (small I know)
AEM Fuel rail with gauge & an adjustment screw for the fuel ratio I think it is
Skunk2 racing cams (just looked to make sure)
Now what I was told not 100% sure
Forged pistons
Forged rods
Skunk2 camshaft
Upgraded valves
Upgraded springs
Old Feb 22, 2012 | 04:30 PM
if u have forged internals u should be able to handle up to 500 horsepower provided they are quality parts. u will need much bigger injectors i have my 450s maxed out at 300 hp and just grabbed some 750s i personally would pull the head and pan off to see for myself though.
Old Feb 22, 2012 | 04:43 PM
queens770's Avatar
That's not a problem, but how would i tell?
Old Feb 22, 2012 | 07:09 PM
DirtyDA9's Avatar
FYI, the guage on the fuel rail isn't for making adjustment...
and you are going to need ALOT bigger injectors for boost.
Also, before you boost it, take the head off to make sure you actually have forged interals and such.
