Wastegate options
Old Mar 1, 2012 | 11:23 PM
92Snatch's Avatar
Default Wastegate options
Hey guys...recently I've been running a open exhaust housing on a open ramhorn manifold. I'm gonna be swapping over to a twin scroll housing and make another manifold (divided). I have a 46mm WG right now, my question is....do u think if I split the WG 50/50 it will be ok, or do u think I should sell it and get twin 38mm??? I wanna be able to still regulate boost at lower levels (say 12-15psi) bc I wanna set it up on boost by gear w/out spikes. What r some of u twin scroll guys running and any issues??? Thanks in advance
Old Mar 2, 2012 | 05:09 AM
TheShodan's Avatar
Moderator
Default Re: Wastegate options
If you're running lower boost pressures like that, just stick to what you have. there aren't any advantages to it unless you're trying run a large framed turbo. If you plan on using a LARGE framed turbo at lowre pressure like you're stating, going Twin 38mm is a much better control option than a single 46mm. If its a slightly smaller turbo (smaller than GT35R, then stay with the 46mm
Old Mar 2, 2012 | 11:12 AM
92Snatch's Avatar
Ok cool....yeah it's a hair bigger than a 35r, I'll put twins then. Thanks man
karmadhi
Oct 1, 2011 04:12 PM
iNERtIA
May 18, 2008 06:18 AM
KillAHonDa
Apr 8, 2008 06:20 AM
jdmtegxsi
Jan 23, 2003 08:23 PM
