-------93 Del Sol Turbo Catch Can HELP!----
So heres whats all to my Del Sol
:D16Z6 Vtec
:Lsd 5speed Transmission
:Skunk2 Intake
:TD05 16G Turbo
:Intercooled
So heres my problem: Recently my catch can is smoking excessivley. When it was first setup it smoked a bit, more of a vapor smoke, but now its smoking way badd.
Heres a picture of what its doing.
Ive been told pcv- dont think its that
Ive been told to vent my crankcase- Hints Catch can setup
Ive been told Ringland- Hoping its not that
Any help would be greatful fellas.
:D16Z6 Vtec
:Skunk2 Intake
:TD05 16G Turbo
:Intercooled
Re: -------93 Del Sol Turbo Catch Can HELP!----
1. Is it a drain back Catch can?
2. If so are you sure the drain isn't kinked?
3. If not have you drained the catch can?
4. Is this picture taken:
- At Idle
- At high RPM
- With the car cold
- With the car hot
5. Is it constantly/steadily smoking? Or does it get dramatically worse when driving the car? Worse in vacuum or boost?
- At Idle
- At high RPM
- With the car cold
- With the car hot
Catch can drains into back of the block-
Im sure its not kinked, i took the can out drained it, cleaned it. put it back in.
I took the 2 hoses off the valve cover and started it up, and the smoke comes from the ports in the valve cover. its is definately internal problem.
Its smoking worse and worse, low oil pressure, boost takes along time to build up.
Finally got pistons pulled..
Im going to replace with all new pistons bearings gaskets.
Probably use stock rods and low compression pistons.
Im just going to run into a problem when it comes back to timing...
Anybody got a good run through of how to set the timing on this d16?
ill take more pictures. they look burnt. one piston looks really clean, the other three are toasty. The rings looks good still though. i think the problem may be within the valves in the head. Taken it to get hot tanked and rebuilt.
i see no cracks in them. i have a rough spot within my 3rd cylinder though. kinda looks like a spider crack. idk if that may the problem or not. Honer may take it out..
have any opinions on these pistons?
http://www.ebay.com/itm/YCP-Vitara-P...sories&vxp=mtr
it may not be a crack..but it you slide your finger nail around it my finger nail catches on it.. Ibet once its honed out itll be gone
Ok, after going back looking at the pistons...
Man you know your stuff...
Ringlands are cracked and just falling apart.....
93hondadelsol8psiturbo
04-30-2005 04:56 PM
