Psi keeps getting lower on d16z6
Old Mar 6, 2012 | 12:33 PM
boostedz6bassma's Avatar
Default Psi keeps getting lower on d16z6
Hey Guys!!
hope all is well! im new to the website just not to the honda game....
well i have a d16z6 in my 4dr eg.
its just a simple ebay setup nothing special. running on 440 rc injectors with a pharable base map chip i ordered. 7 psi waste gate.
i have a ram horn manifold and yeah..
well ever since i switched to my ram horn i am not getting full boost. i did have a waste gate gasket leak which i changed. i am running just straight down pipe at the moment because i am waiting for my exhaust to come in the mail.
here is what my car does.... im good for 7psi when i get on it ill get 4psi out of it and then it will drop down to 3psi till i get into higher rpms and then the boost gauge will jump all around up to 7psi no higher..i just dont get it.... im stumped..some times ill get only 3 psi and itll jump and sometimes ill get 4....
is my turbo going bad..? im not getting turbo smoke or oil leaking anywhere....
anything you guys got just let me know any little bit will help!
let me know if you need more info from me to diagnose this problem!!
thanks alot!!!
Old Mar 6, 2012 | 12:46 PM
HickamHatch's Avatar
Default Re: Psi keeps getting lower on d16z6
Last time my setup did this, the compressor wheel was out of balance and it was hitting the compressor housing and wouldnt let it build boost.
Old Mar 6, 2012 | 01:14 PM
Dc4LsTeG's Avatar
EK9
What kind of wastegate and its an eBay ramhorn?
Old Mar 6, 2012 | 02:20 PM
Nate Case's Avatar
Help!! 93 Del Sol Turbo Catch can smoke : (
Has white Milkish gunk inside the can and is dropping in oil pressure.
Please Help me out here
http://i1155.photobucket.com/albums/...30612_1552.jpg
http://i1155.photobucket.com/albums/...89235343_n.jpg
Old Mar 6, 2012 | 02:22 PM
Dc4LsTeG's Avatar
EK9
And who are you? Create your own thread
Old Mar 6, 2012 | 02:23 PM
Nate Case's Avatar
I cant, lol. new user i guess.
Im same as you bro, shitty d16 turbo junk.
Old Mar 6, 2012 | 02:31 PM
Dc4LsTeG's Avatar
EK9
What do you mean same as me, shitty d16 turbo junk lol I'm not the OP
You should be able to create a new thread. Your problem looks like cracked piston ringlands. Do a compression and leakdown test
Old Mar 6, 2012 | 02:50 PM
Nate Case's Avatar
my bad, ive been tinkering with it all day and i figured theres got to be some honda heads that know what my problem could be. Compression check be my first route to go, also heard venting out my crankcase would be another way to go..
Old Mar 6, 2012 | 02:53 PM
Dc4LsTeG's Avatar
EK9
Your already venting your crankcase that's why you have a catch can
Old Mar 6, 2012 | 03:01 PM
Nate Case's Avatar
That replaces my pcv valve correct?
Old Mar 6, 2012 | 03:03 PM
Dc4LsTeG's Avatar
EK9
Depends how you have it set up. I don't think you need more ventilation you should already have enough. Do a compression test. Like I said its more then likely your ringlands
Old Mar 6, 2012 | 03:05 PM
Nate Case's Avatar
Can you give me a run threw on replacing that?
I have replaced everything on the motor externally, havent touched it internally, kinda building it backwards i guess.
Old Mar 6, 2012 | 03:07 PM
Dc4LsTeG's Avatar
EK9
On replacing what your ringlands?
Old Mar 6, 2012 | 03:13 PM
Nate Case's Avatar
yeah, just pull the head off, drop the oil pan pull the pistons and change rings right?
Old Mar 6, 2012 | 03:15 PM
Dc4LsTeG's Avatar
EK9
Uhh no cracked ringlands would mean replacing the whole piston. I said ringlands not rings,its the part of the piston where the rings sit. Check my build thread if you want to see a pic of a cracked ringland
Old Mar 6, 2012 | 03:17 PM
Nate Case's Avatar
well shoot, while im in there i might as well replace it all. thats what imma do, thanks
Old Mar 6, 2012 | 03:22 PM
Dc4LsTeG's Avatar
EK9
Yep that's what happend to me now I'm doing a full rebuild. Make sure you do a compression and leakdown test before you decide to pull your motor apart
Old Mar 6, 2012 | 03:27 PM
Nate Case's Avatar
Will do. Whats compression suppose to read???
Old Mar 6, 2012 | 03:29 PM
Dc4LsTeG's Avatar
EK9
Depends do it and post your numbers. You don't want a 10% variation in each cylinder
Old Mar 6, 2012 | 06:54 PM
scamp91ex's Avatar
Damn talk about a thread jack! Lol
Old Mar 6, 2012 | 07:39 PM
soooo back to MY THREAD!!!
NATE CASE MAKE YOUR OWN THREAD
Old Mar 6, 2012 | 07:40 PM
its a DNA MOTORING (ebay) ram horn and just some shitty ebay waste gate
does that help?
Old Mar 6, 2012 | 09:26 PM
racebum's Avatar
x2
is my guess as well, the pressure is going in the crankcase, not all in the chamber
i'm also a member of the cracked ringland crew
Old Mar 7, 2012 | 12:06 AM
Shaunathan's Avatar
this is a perfect example why not to purchase things for your car off ebay. Performance Cars is not a cheap hobby and it never will be, if you can't afford to buy decent parts from reputable sources, i suggest either finding a new hobby or you'll find yourself fixing things than actually driving. Stop Cutting Corners
Old Mar 7, 2012 | 02:54 AM
sonicivic's Avatar
wastegate taking a dump?
