Anyone knowledgeable on NITROUIS!!!!
Old Mar 19, 2012 | 03:03 PM
PeteABread's Avatar
Default Anyone knowledgeable on NITROUIS!!!!
Once I have got my rebuild d16 z6 running right I am going to is looking for a bit more power than I originally expected after having a 2.5 st6 BMW during the build. At first I was considering a turbo but the high cost and time consuming nature of that idea put me off as I want another RWD car in the near future.
I stumbled across this nitrous kit
http://www.procivic.com/pages-produc...449/index.html
The Nitrous Express import efi stage 1 nitrous system
thinking about ordering from america as they seem to be more familure with there nitrous
if I hooked up this or a similar system first I was wondering if it would run ok on a 75shot with only up rated spark plugs and spark plug leads to help the burn
Also what sort of power increase could I expect from a system like this?
In my head I am already envisioning stealth nitrous in the ashtray VIN diesel styleeeee
Old Mar 19, 2012 | 03:13 PM
JDM_teh_WIN!!'s Avatar
Default Re: Anyone knowledgeable on NITROUIS!!!!
You could rent all the F&F dvds. They use mad NOS!!!!!!!!!
Old Mar 19, 2012 | 04:37 PM
PeteABread's Avatar
tell me about it there NOS warps light,would be like riding the halon collider
Old Mar 19, 2012 | 05:25 PM
Kohen's Avatar
Holy sh*t.. All the information you want is on that link you posted. Scroll down...
Old Mar 19, 2012 | 06:06 PM
racebum's Avatar
i no scare. 150 shot, stock plugs, 89 octane, no timing pulled....actually, if i remember right i added some timing
Old Mar 19, 2012 | 06:47 PM
Whiterice-gsr's Avatar
halon collider. lmfao.
Old Mar 20, 2012 | 03:12 PM
PeteABread's Avatar
well i will be avoiding the 150 then will be using uprated plugs and sparks hadn't even considered using a 100 shot initially
Old Mar 20, 2012 | 03:23 PM
SiRCiviC94's Avatar
work your way up thats all. I always wanted a hit of a 100 shot
Old Mar 20, 2012 | 05:38 PM
Khnemu's Avatar
It's spelled Nitrous btw and you need more then "uprated plugs"
Old Mar 21, 2012 | 06:27 AM
darkhorizon's Avatar
Run race gas and spray away...
I hate spraying 93... its not worth the risks.
Old Mar 21, 2012 | 07:02 AM
kbouchard1092's Avatar
The safest way is going to be using a dry shot with a Standalone management such as the S300 and utilize the nitrous control feature. Very simple and effective set-up. You will have to run a relay between the output of the ECU and the No2 solenoid. The ecu will turn on the nitrous (there will be no button to hit like the movies) You will have a switch to arm it, and the ECU takes care of the rest based on the parameters you want it activated at
You will be able to add fuel via Injectors and take out Ignition timing the second no2 is activated. This will allow you to dial in a good tune on the dyno with it. This is going to be the safest way of doing it. Then you could even go to a 100shot safely. Without the ablity of tuning fuel/ignition i wouldnt go over a 35/50 shot. Essentially running a dry shot with nitrous control is a Wet kit. Since its increasing fuel thru injectors when nitrous is activated. It is actually a more percise way of controling fuel vs. a wet shot. Since fuel will be evenly distrbuted into each cylinder. If youre budgeting i believe neptune has nitrous control. Im sure alot of the other systems like chrome, ectune may have it as well. I use the S300 and it works flawless.
Old Mar 21, 2012 | 10:08 AM
PeteABread's Avatar
respect on the monster you run about in, due to the complex nature of dry over wet in terms of tuning and cost i am just going to go for a complete wet kit i had only planned on giving it a 50 shot now and again what would you need to say run a 100 shot on a d16z6. already has stage3 clutch, half weight flywheel, 4-2-1 manifold, irradium plugs, AEM fuel pressure regulater also engine went over a major overhaul. Only run on 99 octane
I wont buy new internals like pistons and things just to run nos though
Old Mar 21, 2012 | 10:34 AM
A 100 shot on a stock d16 isnt a good idea. If you dont plan on having any means of tuning i wouldnt go over a 50shot. I think a dry kit would be fine. A wet kit is safer for bigger shots like over 50. However with no means of tuning and a stock d16 i wouldnt advise going over a 50 shot.
Old Mar 21, 2012 | 12:12 PM
TheShodan's Avatar
Moderator
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2A-official-nitrous-thread%2A%2A%2A-2119397/
Slic00Si
May 16, 2004 09:24 PM
out_of_order
May 3, 2004 04:11 AM
civicrights
Dec 1, 2003 08:31 AM
Jeice
Nov 13, 2002 08:41 AM
