Need help on injector
Old Mar 2, 2012 | 02:05 PM
Egpower88's Avatar
Default Need help on injector
Ok I'm not sure what cc injector to go with.. I have a gsr boosting 10psi and looking forwarding to getting 250-300+whp.. I was thinking rc 750cc injector but I don't wanna run a resistor box.. Can I go 650cc?
Old Mar 2, 2012 | 02:27 PM
SilverEK96's Avatar
Default Re: Need help on injector
You can go with the precision 650cc injectors, they don't require resistor box and will be sufficient for your HP you want.
Old Mar 2, 2012 | 03:15 PM
SlickEJ8's Avatar
rc 750 dont need a box
Old Mar 2, 2012 | 03:32 PM
Egpower88's Avatar
It's just from what I heard..
Old Mar 2, 2012 | 03:35 PM
Egpower88's Avatar
Also should I go with saturated or peak/hold??
Old Mar 2, 2012 | 03:46 PM
SlickEJ8's Avatar
saturated
Old Mar 2, 2012 | 04:44 PM
phaphon's Avatar
750 rc saturated should be good it will give you room to grow also.
Old Mar 2, 2012 | 04:45 PM
racebum's Avatar
i have a like new set for sale with obd2a conversion clips. ran all of 50 miles before cylinder 3 cracked. they also come with the correct shims for a honda manifold.
Old Mar 2, 2012 | 05:42 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
interested on how you cracked the cylinder wall
**edit
i just got finished reading your build thread
Old Mar 2, 2012 | 06:58 PM
racebum's Avatar
ringland let go, cylinder wall is fine. just 11:1, early boost and pump gas. didn't take much detonation to knock it. cylinder 3 is also the one that gets the most abuse. 100k of hammering it probably didn't help
i'd do 250 shipped for injectors. like i said, they have 50 miles and you get 40 worth of clips. best price i found online for these was $269 with no clips and no shims
ekcoupeh22
Mar 29, 2012 07:21 PM
