oil feed
Old Feb 22, 2012 | 08:26 AM
Black94sedan's Avatar
Default oil feed
ok I'm new to the site and new to forced induction.im setting up my f22b1 for my t3 application. the question is i have my oil return tapped to the oil pan. where is the best spot for the oil feed ?
Old Feb 22, 2012 | 09:07 AM
DC4KiD's Avatar
Default Re: oil feed
You can T it off from the oil pressure sensor with a brass T-fitting, or get an oil filter adapter plate, like one of these: http://www.ebay.com/itm/OIL-FILTER-S...r#ht_500wt_715
Old Feb 22, 2012 | 10:21 AM
mechanix619's Avatar
I prefer using an oil filter adapter, for me it's cleaner and safer. I don't like the idea of running a "T" fitting off the oil pressure sensor. With that said, everyone has their own opinions and styles, this is just mine.
Golden Eagle
http://www.goldeneaglemfg.com/index....roducts_id=302
Old Feb 27, 2012 | 02:51 AM
Thank you guys I ordered the sandwhich adapter should be in wednesday
Old Feb 27, 2012 | 03:05 AM
ej8munster's Avatar
since we are on the subject of sandwich plates you can feed the oil through an oil cooler pre turbo an run an oil pressure/temp gauge as well.... reliability is a nice deal btw what turbo an make sure you run an oil pressure restricter or ya may end up with bad oil seal on the turbine smokey exhaust = doh
HPfreak
Nov 9, 2011 01:24 PM
hndacord02
May 30, 2010 07:23 AM
creechrr
Jan 2, 2007 02:04 PM
THEROPE
Dec 13, 2005 07:17 PM
Racerage1
Apr 11, 2003 11:01 PM
